Reggae tutorials: using http.stream
    Krashan
    Posts: 1107 from 2003/6/11
    A new Reggae tutorial with 3 example applications is available in the MorphZone Library. One of examples is just ready to use HTTP downloader with support for files longer than 4 GB (on 64-bit filesystems of course). This is the first part of http.stream tutorial, the second one will cover more advanced stuff.
  • »28.08.10 - 15:58
    weiseb
    Posts: 215 from 2003/3/29
    Thank you. I compiled the downloader yesterday and will take a closer look later this week.
  • »30.08.10 - 04:24
