Posts: 472 from 2006/2/23
No problem, you can always count on me. First of all, i unpacked your archive and Pack_PatIcon_v2.1 drawer is inside Pack_PatIcon_v2.1, better than having all unpacked files in one place at least ;). In Pack_PatIcon_v2.1/Pack_PatIcon_v2.1/[Skin]/BlueMorph/ There is a readme file from my knskin, no idea why you put it there. Gadgets inside are made by trima, so he should be credited instead. Shadow of icons over folders is too strong, but I'm not enough crazy to use a diffrent icon for each app anyway ;). Some icons have strange dimensions. I can say that your folder icon is nice, wallpapers are nice as well and that's why you should focus more on your own work (a little suggestion :) ). Check the lower part of "best os", few lines are transparent, image itself shouldn't have an alpha channel when it isn't needed btw.
