Screensaver
    Posts: 186 from 2003/10/23
    maybe this is the correct place to ask :D
    anyboy have a "skeleton" code to build up from zero a screensaver blanker?
    I've seen amigazeux "modern" blanker, but the code is in E,and we have only the "executable".
    I 've watched the .h included in the sdk, but dosen't help me much.
    I've also watched the skeleton code from the original Beyond the Dark, but i doubt the api is the same.
    so any suggestion, from where to start?
    I'm nerdy in the extreme
    And whiter than sour cream
    White&Nerdy 2006 Al Yankovic
  • »21.09.09 - 08:15
    Posts: 647 from 2004/4/15
    Very good question!
    No MorphOS-Devs reading here?
    To complement the question: When will a new SDk be released (new includes, altivec, ...)?
    I can remember that it should be realesd together with MorphOS 2.3? Or was it MorphOS 2.4?
  • »22.09.09 - 14:18
    the new sdk is actually missing , but it's possible to use the new features of morphos with the new includes stored on the morphos-team, or lucky or krashan pages.
  • »22.09.09 - 16:25
    Gelb
    Posts: 148 from 2003/3/4
    if you want to have a look at ModernArtBlanker source code I've uploaded it here. You won't be able to compile it as there are several modules missing, but it should give you an idea of how things are done.
    I hope this is of any help even though the code is in E as you found out already :-)
  • »23.09.09 - 00:09
    great :D
    Thanks, Gelb.
  • »23.09.09 - 11:29
    Posts: 3300 from 2003/3/5
    I'll try to prepare some blanker skeleton for C for you and put it here. Basically it's just a PPC library.
  • »23.09.09 - 17:08
    yessssss!!!
    thank Jacad :D
  • »23.09.09 - 20:03
