AHI Mic in on PegasosII
    Posts: 4 from 2004/8/4
    I want to write some signal processing code for MorphOS and therefore
    I need to read samples from the mic. I use a plain PegasosII with the
    integrated AC97, no additional sound card.
    I thought that I might just use AHI to read from microphone but when
    I tried the hard disk recording demo from the AHI developer archive
    it just came back after less then half a second (I did a setting that
    it shall record about 5 s) and nothing was recorded; I connected
    my mic to microphone input on the back side of my Pegasos.
    Before I dig in too deeply just to find out that it is not working at all:
    Does anybody of you know, how to read samples (i.e. with AHI) and
    where to find some example code and if it is possible at all?
    Or is it that I just did some mistake and that the standard AHI hard disk
    recording example should work?
    Thanks in advance for your answers and best regards
    (Dent)
  • »16.08.04 - 09:02
    Jupp3
    Posts: 1193 from 2003/2/24
    I've succesfully recorded samples with AHIRecord using line-in.
  • »16.08.04 - 10:31
    DJBase
    Posts: 745 from 2003/4/6
    Yes, AHIRecord is working perfect. Thats the way to go.
  • »16.08.04 - 13:59
  • tom
    tom
    Posts: 148 from 2003/7/22
    I've tried AHIrecord but it doesn'y work on my Peg I. I've a soundblaster in my Peg so I use EMU10kx for sound. So perhaps that's the problem?
    Tom
  • »16.08.04 - 17:17
    Black_Eagle
    Posts: 70 from 2003/6/5
    I can only record with line-in. Haven't found any program that handles the microphone input so far, unfortunately =(
    With AHIRecord I can only see Input -> Mixer and Monitor -> Line... No microphone or anything else.
    [ Edited by Black_Eagle on 2004/8/16 21:29 ]
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »16.08.04 - 17:25
