ObjC sample project from scratch
    asrael22
    Posts: 451 from 2014/6/11
    Hi.
    I'm current playing with the ObjC implementation and trying to get a simple Hello World working.
    After creating a new project in FlowStudio and simple main.c that prints a HGelloWorld using printf works fine.
    But when adding a new ObjC class and linking I get a linker error like this:
    make: Entering directory '/Work/DevelAdd/Sources/objc/FooTest319'
    compiling main_RELEASE.o
    › q› qcompiling AppMain_RELEASE.mo
    › q› qlinking FooTest
    /gg/ppc-morphos/bin/ld: /gg/ppc-morphos/lib/libobjfwrt.library.a(linklib.o): in function `ctor':
    /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:102: undefined reference to `_Unwind_RaiseException'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:68: undefined reference to `_Unwind_DeleteException'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:70: undefined reference to `_Unwind_GetLanguageSpecificData'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:102: undefined reference to `_Unwind_GetRegionStart'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:102: undefined reference to `_Unwind_GetDataRelBase'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:102: undefined reference to `_Unwind_GetTextRelBase'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:105: undefined reference to `_Unwind_GetIP'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:105: undefined reference to `_Unwind_GetGR'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:105: undefined reference to `_Unwind_SetIP'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:105: undefined reference to `_Unwind_SetGR'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:105: undefined reference to `_Unwind_Resume'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:105: undefined reference to `__register_frame_info'
    /gg/ppc-morphos/bin/ld: /home/jaca/morphos/morphoswb/classes/frameworks/objfw/ObjFW/src/runtime/linklib/linklib.m:105: undefined reference to `__deregister_frame_info'
    collect2: ld returned 1 exit status
    make: *** [Work:DevelAdd/Sources/objc/FooTest319/Makefile:79: FooTest] Error 1
    make: Leaving directory '/Work/DevelAdd/Sources/objc/FooTest319'
    The ObjC code is quite simple:
    #import <ob/OBFramework.h>
    #include "stdio.h"
    @interface MainApp : OBObject
    @end
    @implementation MainApp
    - (void) main {
    printf("Hello from MainApp.");
    @end
    Any idea what the problem is?
  • »17.10.25 - 13:16
    Posts: 3332 from 2003/3/5
    The Flow defaults are unfortunately a little wrong. See if
    ppc-morphos-gcc-9 -o objc objc.m -I /SDK/Frameworks/include -lob.framework -lobjc -noixemul
    works.
    Alternatively -lob-fw.framework -lobjfwrt -noixemul to link with ObjFW runtime.
  • »18.10.25 - 16:20
    asrael22
    Cool, thanks.
    The former works.
    The latter raises error:
    /System/Development/gg/bin/../lib/gcc-lib/ppc-morphos/9.5.0/../../../../ppc-morphos/bin/ld: cannot find -lobjfwrt: No such file or directory
    Regarding ObjFW, can one use the full ObjFW framework?
  • »20.10.25 - 13:13
    Sorry, we're changing names of some libs so I might have given you a wrong one there :)
    As for ObjFW - if you want to create a UI app, you need to stick to ob.framework and mui.framework (which can optionally use objfw runtime). If you want to use ObjFW you can, but it would require bridging between objfw and ob.
    Btw you can build full ObjFW yourself from its source - it'll build and work on MorphOS.
  • »20.10.25 - 16:56
    asrael22
    That's awesome.
    Will this be fixed in FlowStudio in next MorphOS release? Some (or one at least) application templates when for starting a new project would be cool as well.
  • »20.10.25 - 17:47
    Yes, that's the plan.
  • »20.10.25 - 18:00
    asrael22
    It's "-lobjfwrt.library"
    So this little example compiles fine with objfw runtime. The executable it quite a bit smaller. It is because of missing UI code?
    Hmm, I tried it. But "configure" doesn't seem to exist. "autogen.sh" errors with "aclocal: not found".
    Probably I can just tweak the Makefile but I wouldn't know how.
    But my main question actually is, in order to use ObjFW I'd need the includes. But can't find them.
  • »28.10.25 - 05:56
    asrael22
    OK, I managed to create a cross-tool-chain (although building this on MorphOS itself would be nice).
    Then I got this output:
    ➜ ObjFW git:(main) l /opt/objfw-mos/lib
    insgesamt 7,8M
    drwxr-xr-x 3 root root 4,0K Okt 28 16:24 .
    drwxr-xr-x 7 root root 4,0K Okt 28 16:24 ..
    -rw-r--r-- 1 root root 7,1M Okt 28 16:24 libobjfw.a
    -rw-r--r-- 1 root root 489K Okt 28 16:24 libobjfwhid.a
    -rw-r--r-- 1 root root 42K Okt 28 16:24 libobjfwrt.library.a
    -rw-r--r-- 1 root root 107K Okt 28 16:24 libobjfwtest.a
    -rw-r--r-- 1 root root 70K Okt 28 16:24 libobjfwtls.a
    drwxr-xr-x 2 root root 4,0K Okt 28 16:24 objfw-config
    ➜ ObjFW git:(main) l /opt/objfw-mos/Libs
    insgesamt 292K
    drwxr-xr-x 2 root root 4,0K Okt 28 16:24 .
    -rwxr-xr-x 1 root root 283K Okt 28 16:24 objfwrt.library
    Does this look kinda right? What do I do with it now?
  • »28.10.25 - 13:29
