Boost Sources: Cannot utime: Argument list too long
    beworld
    Posts: 664 from 2010/2/10
    Great :-)
    i look into source... and i try to build it with your readme help
    and filesystem/iostream need to be rewrite i think :-(
    i see some "bind" redefined... and lot of ixemul thing not available with noixemul
    PowerMac G5 Quad 2.5, IMac G5 2.1, PowerBook G4 1.5, MacMini 1.5
    My MOS ports
  • »18.01.25 - 06:06
    Posts: 3252 from 2003/3/5
    An ixemul build will not be very useful since it can only be used for ixemul commandline apps. Bind errors likely come from macros in socket headers. You likely need some #undefs.
  • »18.01.25 - 12:51
    beworld
    yeah.. i always have this bind lol
    and indeed... all build done with noixemul :-)
    My MOS ports
  • »18.01.25 - 13:50
    Posts: 643 from 2004/4/15
    What I have done so far:
    Introduced boost/config/platform/morhphos.hpp:
    #define BOOST_PLATFORM "MorphOs"
    #ifdef __cplusplus
    #include <cstdlib>
    #else
    #include <stdlib.h>
    #endif
    #ifndef __STDC_LIMIT_MACROS
    #define __STDC_LIMIT_MACROS
    #endif
    #include <boost/config/detail/posix_features.hpp> // not sure about this
    Add the header into boost/config/detail/select_platform_config.hpp:
    #elif defined(__morphos__)
    // MorphOs (put this before the AmigaOS statement)
    # define BOOST_PLATFORM_CONFIG "boost/config/platform/morphos.hpp"
    Put user-config.jam in root dir:
    using gcc : power : /gg/bin/ppc-morphos-g++-11 ;
    build command:
    ./b2 cxxflags="-std=c++17" cflags="-noixemul -D__morphos__" toolset=gcc-power link=static threading=single variant=release optimization=speed
    --user-config=/home/andre/workspace/other/boost_1_87_0/user-config.jam
    --build-dir=/tmp/boost-build
    --prefix=/tmp/boost-install
    --with-atomic
    --with-chrono
    --with-program_options
    --with-system
    --with-random
    --with-test
    --with-locale
    --with-filesystem
    --with-iostreams
    install
    program_options fails: don't know why, because it should do
    filesystem fails: missing POSIC filesystem implementation
    iostreams fails: did not look inside yet
    There is some work to do.
    Maybe it is a good idea to share our work in a git repo?
  • »19.01.25 - 09:29
    Yes your absolutely right. That's not an good idea.
  • »19.01.25 - 09:30
    beworld
    Yeah i think i think it's good idea
    My MOS ports
  • »19.01.25 - 10:01
    beworld
    i push a little (very little) contribution
    My MOS ports
  • »19.01.25 - 15:16
    I rebased an merged your branch into develop.
  • »21.01.25 - 06:13
    I managed also to include iostreams.
    Updated the git repo and uploaded a build to morphos-storage.
    For return to the roots everything should be there.
  • »31.01.25 - 08:21
    beworld
    thanks i will try to build it
    My MOS ports
  • »31.01.25 - 10:29
    Hey, did you try it?
    I updated the git repo and added more submodules and also a Makefile to cross-compile all
    and package it.
  • »07.02.25 - 07:14
    beworld
    hi, hard to test... s25 is complex project... i pass some time on it but need a lot of time to adapt all problem :-(
    Need to find something less hard...
    My MOS ports
  • »07.02.25 - 07:43
    Yes, that's true.
    I add 2 simple examples for filesystem, see: https://github.com/eliot-exdev/boost-morphos/tree/develop/examples_mos
    The c++17 example works well, the boost example fails to link (missing symbols when using -noixemul).
    So we need to replace those calls.
    I will have look into it, this needs more love.
    [ Edited by eliot 07.02.2025 - 10:47 ]
  • »07.02.25 - 09:46
    Those symbols are missing:
    operations.cpp:(.text+0x1804): undefined reference to `link'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: /tmp/boost-1.87.0-morphos-ppc/lib/libboost_filesystem.a(operations.o): in function `_ZN5boost10filesystem6detail14create_symlinkERKNS0_4pathES4_PNS_6system10error_codeE':
    operations.cpp:(.text+0x18a4): undefined reference to `symlink'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: /tmp/boost-1.87.0-morphos-ppc/lib/libboost_filesystem.a(operations.o): in function `_ZN5boost10filesystem6detail15last_write_timeERKNS0_4pathElPNS_6system10error_codeE':
    operations.cpp:(.text+0x3df4): undefined reference to `utime'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: /tmp/boost-1.87.0-morphos-ppc/lib/libboost_filesystem.a(operations.o): in function `_ZN5boost10filesystem6detail12read_symlinkERKNS0_4pathEPNS_6system10error_codeE':
    operations.cpp:(.text+0x40f0): undefined reference to `readlink'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: operations.cpp:(.text+0x41e4): undefined reference to `readlink'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: /tmp/boost-1.87.0-morphos-ppc/lib/libboost_filesystem.a(operations.o): in function `_ZN5boost10filesystem6detail12copy_symlinkERKNS0_4pathES4_PNS_6system10error_codeE':
    operations.cpp:(.text+0x43f0): undefined reference to `symlink'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: /tmp/boost-1.87.0-morphos-ppc/lib/libboost_filesystem.a(operations.o): in function `_ZN5boost10filesystem6detail5spaceERKNS0_4pathEPNS_6system10error_codeE':
    operations.cpp:(.text+0x565c): undefined reference to `statfs'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: operations.cpp:(.text+0x56f4): undefined reference to `statfs'
    /gg/lib/gcc-lib/ppc-morphos/11.3.0/../../../../ppc-morphos/bin/ld: /tmp/boost-1.87.0-morphos-ppc/lib/libboost_filesystem.a(operations.o): in function `_ZN5boost10filesystem6detail4copyERKNS0_4pathES4_NS0_12copy_optionsEPNS_6system10error_codeE':
    operations.cpp:(.text+0x8474): undefined reference to `symlink'
    But I can find them here (eg. readlink):
    grep -rH "readlink" /gg/
    grep: /gg/ppc-morphos/lib/libb32/libc.a: binary file matches
    grep: /gg/ppc-morphos/lib/libc.a: binary file matches
    /gg/includestd/unistd.h:int readlink __P((const char *, char *, int));
    Is there more information about ixemul.library and -noixemul compile flag?
    There it is:
    andre@drax:/gg/ppc-morphos/lib$ ar x libc.a
    andre@drax:/gg/ppc-morphos/lib$ file readlink.o
    readlink.o: ELF 32-bit MSB relocatable, PowerPC or cisco 4500, version 1 (SYSV), not stripped
    Why it is not linked?
    My gcc call:
    /gg/bin/ppc-morphos-g++-11 -o example-filesystem-boost example-filesystem-boost.cpp -Ofast -noixemul -DNDEBUG -D__MORPHOS__ -std=c++17 -I/tmp/boost-1.87.0-morphos-ppc/include -static -L/tmp/boost-1.87.0-morphos-ppc/lib -lboost_filesystem
    [ Edited by eliot 07.02.2025 - 17:54 ]
  • »07.02.25 - 16:28
