cmake command line parsing broken
    Posts: 655 from 2004/4/15
    when I try to set some definitions with a space in cmake, cmake interprets it wrong.
    Example which works:
    cmake -DCMAKE_C_FLAGS="-noixemul" ../
    But when I want to put some more definitions into the command line it breaks:
    cmake -DCMAKE_C_FLAGS="-noixemul -mcpu=G4 -maltivec -mabi=altivec" ../
    Everything after -noixemul is interpreted as path.
    Maybe on MorphOS I have to escape the string value with spaces in a different way,
    but I don't know how.
    What I tried so far:
    '-noixemul -mcpu=G4 -maltivec -mabi=altivec'
    -noixemul\ -mcpu=G4\ -maltivec\ -mabi=altivec
    Is that a cmake error on MorphOS or I am doing it wrong?
  • »02.02.25 - 06:06
    Posts: 110 from 2020/12/24
    Yep, it can happens even for other platforms. Maybe try "setenv" the C_FLAGS with all the parameters inside quotes as you tried.
    I have some projects that fail the same way with ".configure", and "setenv" before calling it works for me.
  • »02.02.25 - 07:15
    Hm, no, on all other platforms (Linux, Mac, Windows)
    it works like expected.
    But setenv might be a workaround
    [ Edited by eliot 02.02.2025 - 10:26 ]
  • »02.02.25 - 09:24
    Is the cmake source of Mos sdk public?
    Maybe I can fix this and also update it to newer release?
  • »02.02.25 - 09:30
    beworld
    Posts: 683 from 2010/2/10
    You can find cmake 3.16.2 here: https://github.com/jacadcaps/webkitty/tree/morphos_2.46.5
    @Jaca possible to release it (or maybe new SDK) or it's specific to wayfarer ?
    My MOS ports
  • »02.02.25 - 10:09
    That's WebKit, not cmake.
    System:> which cmake
    System:Development/gg/bin/cmake
    System:> cmake --version
    cmake version 3.9.6
    CMake suite maintained and supported by Kitware (kitware.com/cmake).
    cmake is part of the SDK, but it's not listed on MorphOS sources: https://www.morphos-team.net/sources
    [ Edited by eliot 02.02.2025 - 12:08 ]
  • »02.02.25 - 11:01
    tolkien
    Posts: 585 from 2013/5/29
    Will wait for the next SDK updates...
  • »02.02.25 - 12:57
    Is there anything planned in near future?
    Will that problem be fixed?
  • »02.02.25 - 13:42
    tolkien
    Generally there is an SDK update after an OS updates.
    But dont know if this issues will be fixed.
  • »02.02.25 - 13:48
    Posts: 12557 from 2003/5/22
    Usually only after feature releases (= even revision number). Last SDK after bugfix release (= odd revision number) was the one released with MorphOS 3.9 a decade ago.
  • »02.02.25 - 14:36
    tolkien
    Oh yes...thats precise information.
    Thanks.
  • »02.02.25 - 16:30
    Posts: 3336 from 2003/3/5
    Are you doing this in ksh or the AmigaDOS shell? Both have different ways of parsing the commandline. I'd suggest running cmake via make. That way you'll jump right into ixemul path parsing.
  • »02.02.25 - 19:31
    It's part of the SDK Source archive you can find on our website.
  • »02.02.25 - 19:32
    Next SDK will most likely be released together with MorphOS 3.20.
    I don't think this problem is actually cmake, more like sh or some interaction between ixemul and non-ixemul shells. Again, try calling it via make or run sh first.
  • »02.02.25 - 19:34
    @ jacadcaps
    Yes, your are right. Running cmake from sh (ksh) and the problem is gone.
    Building cmark and other programs like this now works:
    Work:workspace/cmark/build> which sh
    System:Development/gg/bin/ksh
    Work:workspace/cmark/build> sh
    $ pwd
    /Work/workspace/cmark/build
    cmake --build . --target cmark_exe --config Release
    $ exit
    Thanks for tip.
    So I can now do native builds of boost with cmake directly on MorphOS.
  • »03.02.25 - 04:53
    Yes, thanks. I just looked onto the website but not into the source archive.
    I found it, thanks!
  • »03.02.25 - 04:55
