EmulCallQuick68k how to
    alfie
    Posts: 96 from 2005/3/25
    The following is with EmulCall68k.
    #include <proto/exec.h>
    #include <stdio.h>
    struct Library *RexxSysBase;
    int toupper(int c)
    struct EmulCaos ec = {0};
    ULONG fun, res;
    fun = (ULONG)RexxSysBase-0x126;
    ec.caos_Un.Function = (APTR)fun;
    ec.reg_d0 = (ULONG)c;
    ec.reg_a6 = (ULONG)RexxSysBase;
    res = (*MyEmulHandle->EmulCall68k)(&ec);
    return (int)res;
    int main(int argc,char **argv)
    ULONG res;
    if (argc!=2)
    return 1;
    RexxSysBase = OpenLibrary("rexxsyslib.library",0);
    if (!RexxSysBase)
    return 1;
    res = toupper(argv[1][0]);
    printf("%c %cn",argv[1][0],res);
    CloseLibrary(RexxSysBase);
    return 0;
    How to do the same using EmulCallQuick68k?
    P.S.
    I am asking this silly question(s), because this is the convoluted way I use to call some function, f.e. CVs2i:
    being the 68k asm:
        _CVs2i:
    move.l d1,-(a7)
    move.l a1,-(a7)
    jsr _LVOCVs2i(a6)
    movea.l (a7)+,a1
    move.l d1,(a1)
    move.l (a7)+,d1
    rts
    I use a ridiculous:
    static UWORD CVs2i_code[] =
    0x2F01,
    0x2F09,
    0x4EAE, 0xFE26,
    0x225F,
    0x2281,
    0x221F,
    0x4E75
    int
    CVs2i(struct RexxArg *ss,LONG *value,struct RxsLib *base)
    REG_A0 = (ULONG)ss;
    REG_A1 = (ULONG)value;
    REG_A6 = (ULONG)base;
    return (int)(*MyEmulHandle->EmulCallDirect68k)(CVs2i_code);
    which is too much :P
    [ Edited by alfie 04.06.2024 - 09:16 ]
  • »04.06.24 - 05:06
    Piru
    Posts: 595 from 2003/2/24
    You can use the macros in ppcinline/macros.h for this. If you have return a value and a single argument LP1 macro is appropriate:
    int mytoupper(int c)
    return (int) LP1(0x126, int, mytoupper, int, c, d0, , RexxSysBase, 0, 0, 0, 0, 0, 0);
    Or just the code that it will evaluate to:
    ULONG res;
    REG_D0 = (ULONG) c;
    REG_A6 = (ULONG) RexxSysBase;
    res = MyEmulHandle->EmulCallDirectOS(-0x126);
    return (int) res;
    Note that it is not a good idea to replace Standard C library toupper in case some other linklibrary calls it and expects specific behaviour which might not be replicated by the RexxSysBase function.
    The 2nd case indeed is a bit special as MorphOS 68k emul interface doesn't support return values in other registers than d0. A stub like that storing the additional return values is the only way.
  • »04.06.24 - 13:11
    alfie
    Thanks Piru.
    toupper was only to write a vary basic example.
    The matter is whatever I do, I always crash trying to use Quick; I remember 20 years ago I had the very same problem: no way to make Quick works.
  • »04.06.24 - 14:35
    Piru
    EmulCallQuick68k is tricky to use. Typically you need to set up the call with assembler stub in order to cater for the requirements of the call. If you just call the function directly from C it can wipe r13-r31, something that the C compiler is not aware of. So combining the call with any complicated C code will likely result in a crash.
    Generally it should not be used by user applications.
  • »06.06.24 - 19:09
    alfie
    I see, thanks again.
  • »10.06.24 - 18:01
