Simple code question
    Blasterreal
    Posts: 41 from 2007/3/30
    Hi, i create simple Fahrenheit / Celcius converter with MUI, But i get little error, i think contents value must be float, how do that via MUI
    switch(id)
    case MUIV_Application_ReturnID_Quit:
    running = FALSE;
    break;
    case CALCULATE:
    float cell;
    get(fahrenText, MUIA_String_Contents, &contents);
    cell =(5.0/9.0) * (contents - 32.0); //ERROR main.c:127: invalid operands to binary -
    set(celciusText, MUIA_String_Contents, cell);
    break;
  • »01.01.23 - 17:43
    Posts: 3266 from 2003/3/5
    MUIA_String_Contents must be a string, so you'll have to format your float into a temporary one first.
  • »01.01.23 - 18:13
    Blasterreal
    Thx jaca,
    Solition here, it work now
    switch(id)
    running = FALSE;
    break;
    case CALCULATE:
    float cell;
    float value;
    char value2[32];
    value = atof (contents);
    cell =(5.0/9.0) * (value - 32.0);
    sprintf (value2, "%f", cell);
    set(celciusText, MUIA_String_Contents, value2);
    break;
  • »01.01.23 - 18:38
