Visual Studio Code in Wayfarer
    Posts: 3319 from 2003/3/5
    It's been brought to my attention that it works, so I thought I'd share:
    A web version of VSCode integrated with github works in Wayfarer (with some caveats). To run, sign in into github, go to your favourite repository and press . (dot). This will forward you to fe https://github.dev/jacadcaps/gamepadlib.
    Hint: for editing to work, you need to use a Safari user agent.
  • »04.06.22 - 11:44
    tolkien
    Posts: 578 from 2013/5/29
    I tried VScode web with previous versions of wayfarer and it worked.
    Vscode is a great editor but is slow in my 2ghz g5.
    I imagine is all those js running in the background.
    Anyway, its great that wayfarer has the compability level to can run vscode.
  • »05.06.22 - 03:33
