Git OAuth Tokens on GitHub?
    Samurai_Crow
    Posts: 198 from 2009/12/10
    I just tried out the new Git executable from the 3.16 development kit. After I committed my changes to my Hollywood scripts I got an email pointing me to a Github.blog post. Will future versions of Git or FlowStudio support Git with the OAuth2 protocol?
  • »31.12.20 - 22:50
    Posts: 3336 from 2003/3/5
    You just need to configure your SSH pubkey on github and use that with git - normally automagic.
  • »31.12.20 - 23:20
    Samurai_Crow
    Thanks for the tip!
  • »01.01.21 - 14:23
    emeck
    Posts: 175 from 2014/7/15
    Thanks. Changed for my repos at bitbucket and github. Seems to be ok.
    For those interested, this helped me.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »01.01.21 - 17:55
    Samurai_Crow
    I was able to generate a key but the ssh-add command doesn't seem to be present on MorphOS. I tried "ssh --add" and so on with a space in between but it didn't ask for my pass phrease. The key is added to GitHub though.
  • »01.01.21 - 21:22
    Piru
    Posts: 624 from 2003/2/24
    ssh-agent isn't available as for now. Luckily ssh keys work without ssh-agent, too. It's not as convenient as it could be, since you need to enter the key passphrase a lot then.
  • »01.01.21 - 22:03
    emeck
    As Piru wrote, ssh-agent is not available so we need to enter the passphrase everytime. But not a big deal for me. Right now I have just a single beginner's Hollywood project, so I don't push commits every day. The other option would be to create the key with a blank passphrase.
    @Piru
    Is ssh-agent in the To-do list?
    [ Edited by emeck 02.01.2021 - 02:18 ]
  • »02.01.21 - 00:18
    Piru
    emeck wrote:
    @Piru
    I just got it working last night, so you can expect ssh-agent to be included in future SDK release. Due to some limitations Code:
    eval `ssh-agent`
    use pattern won't work, but Code:
    ssh-agent sh
    one does.
  • »02.01.21 - 12:04
