MorphOS Developer
Posts: 3332 from 2003/3/5
Thought it'd share some of the stuff I keep on github these days. Will post here if new examples/projects pop up there.
https://github.com/jacadcaps/gamepadlib gamepad lib is a simplified way of accessing gamepads and joysticks via sensors.library. Everything is mapped as a x360 gamepad for convenience.
https://github.com/jacadcaps/multimediatags A simple tool to dump file's meta data using Reggae.
https://github.com/jacadcaps/stackvector A C++ example of a vector that can either use stack or heap to provide temporary storage, along with some ObjectiveC++ examples to optimize OBArray enumeration. Uses a technique commonly used in gamedev (using stack for storage of objects that were also allocated on stack).
