S_ISDIR (dirent.h) ?!
    beworld
    Posts: 683 from 2010/2/10
    I try a simple code "c" :
    #include <stdio.h>
    #include <stdlib.h>
    #include <string.h>
    #include <math.h>
    #include <time.h>
    #include <sys/types.h>
    #include <sys/stat.h>
    #include <proto/dos.h>
    #include <dirent.h>
    int main(int argc, char * argv[])
    struct dirent* entry;
    struct stat buf;
    DIR* current_directory;
    char curdir[FILENAME_MAX];
    sprintf(curdir,"MORPHOS:%s","");
    current_directory = opendir(curdir);
    while ((entry=readdir(current_directory)))
    printf("filename=%s ",entry->d_name);
    stat(entry->d_name, &buf);
    if (S_ISDIR(buf.st_mode)) {
    printf(" is dir n ");
    } else{
    printf("is file n");
    closedir(current_directory);
    return(0);
    Juste list files and directory of my MORPHOS: volume, and check if are directory or file :
    Result.. i dont understand, anyone can help me ?
    filename=MorphOS.readme is file
    filename=MorphOS.readme.info is file
    filename=MorphOS is file
    filename=Development is file
    filename=Development.info is file
    filename=Applications.info is file
    filename=disk.info is file
    filename=Data is file
    filename=Classes.info is file
    filename=Devs.info is file
    filename=Docs.info is file
    filename=Games.info is file
    filename=WBStartup.info is file
    filename=C is file
    filename=L is file
    filename=Libs is file
    filename=Locale is file
    filename=S is file
    filename=Tools is file
    filename=Utilities is file
    filename=WBStartup is file
    filename=Storage.info is file
    filename=Storage is file
    filename=Prefs.info is file
    filename=Tools.info is file
    filename=Utilities.info is file
    filename=Locale.info is file
    filename=Prefs is file
    filename=Applications is file
    filename=Classes is file
    filename=Devs is file
    filename=Docs is file
    filename=Fonts is file
    filename=Games is file
    filename=Emulation is file
    filename=Emulation.info is file
    thanks you.
    BeWorld
    My MOS ports
  • »29.12.19 - 16:09
    Posts: 3336 from 2003/3/5
    Not "C" but POSIX, really. You didn't tell us whether you've compiled this for libnix or ixemul, by the way.
  • »29.12.19 - 16:20
    beworld
    CFLAGS = -02 -Wall
    LIBS= -noixemul
    I use gcc 9 SDK 3.14
    [ Edité par beworld 29.12.2019 - 20:49 ]
    My MOS ports
  • »29.12.19 - 16:24
    Piru
    Posts: 623 from 2003/2/24
    stat() is failing and thus 'buf' is random (or rather whatever happens to be in the stack previously). You must check that the stat() return value is 0 before using 'buf'.
    stat() fails because you're not in the correct directory.
    [ Edited by Piru 30.12.2019 - 08:47 ]
  • »29.12.19 - 20:18
