ObjFW
    asrael22
    Posts: 451 from 2014/6/11
    Hi.
    In which way is there support for ObjFW runtime?
    I was looking for 'objfw-new' and other tools, but couldn't find them.
    Is there an example project?
    Please advice,
    Manfred
  • »07.10.19 - 18:06
    Posts: 3332 from 2003/3/5
    We're using the ObjFW runtime, not the whole thing. If you want to use full ObjFW, get it from github and build it yourself. That'll not let you build an app with ObjC-MUI though, at least for now.
  • »07.10.19 - 19:20
    asrael22
    OK, fair enough.
    I have some small frameworks which I coded years ago for Mac.
    I'm thinking about porting them to MorphOS.
    is -UTF8String method available in OBString now?
    Well, don't worry, I'll check.
    Manfred
  • »08.10.19 - 04:33
    cString returns an UTF8 encoded string.
  • »08.10.19 - 04:51
