Posts: 585 from 2013/5/29
Damm!!! I have spend two days trying to find a way!! hahahahaha
Ok mates. Thanks the support. I can wait "a bit" ;)
igracki escribió:
Unfortunately, I didn't found a way to get the filename of the current tab.
I got used to it to have the fullpath of the file in the first line as a comment to compile my ECX/Hollywood sources.
My compile script reads this and starts the corresponding compiler;)
Hey! I think I can use this trick meanwhile! Thanks.
[ Editado por tolkien 19.03.2019 - 19:58 ]MorphOS: PowerMac G5 - PowerBook G4 - MacMini.
