altivec and C - mission inpossible
    imax
    Posts: 41 from 2004/9/20
    Hello !
    i need speed up for critical time code.
    1. how use variables for use altivec register ?
    2. how use assembler code for include to GCC C code ?
    Is it possible ?
  • »22.01.19 - 17:19
    Posts: 3332 from 2003/3/5
    2. I think this is what you want to read about: https://gcc.gnu.org/onlinedocs/gcc/Extended-Asm.html
  • »22.01.19 - 18:08
    CISC
    Posts: 619 from 2005/8/27
    You might want to read about AltiVec Intrinsics too, you don't have to use asm.
    - CISC
  • »23.01.19 - 05:42
    Intuition
    Posts: 1116 from 2013/5/24
    imax wrote:
    Hello !
    Is it possible ?
    Have you tried using -Ofast -maltivec -mabi=altivec as gcc flags?
    [ Edited by Intuition 28.01.2019 - 19:56 ]
  • »28.01.19 - 18:55
    BSzili
    Posts: 570 from 2012/6/8
    I doubt that will do much, auto-vectorization in GCC was never really good.
  • »29.01.19 - 10:19
    Intuition
    It depends on the code, no harm in trying.
    -mavx makes a huge difference on some code I've been working with recently that uses a lot of vec3's.
  • »29.01.19 - 18:11
    Tom01
    Posts: 187 from 2009/9/20
    Remember, that Altivec-Data has to be 16 Byte alligned.
    And to enable Vectorization of Floating-Point-Reductions add -ffast-math
    [ Edited by Tom01 01.02.2019 - 23:00 ]
  • »31.01.19 - 16:33
