MorphOS development & UTF-8
  • Leo
    Leo
    Posts: 426 from 2003/8/18
    I tried to compile a simple hello world which prints UTF-8 characters using printf():
    #include <stdio.h>
    int main(void) {
    char ver[] = "©«",
    ver2[] = "的",
    ver3[] = "$VER: test caractères: ©«的";
    printf("ver: %sn", ver);
    printf("ver2: %sn", ver2);
    printf("-------n");
    printf("的n");
    printf("的n");
    return 0;
    The source file is saved as UTF-8, and I compiled it using gcc file.c -noixemul.
    When I run it in a MorhOS shell, here is what I get instead:
    ver: ©«
    ver2: ç
    Is UTF-8 supported in MorphOS? What encoding should be used to save files with special characters?
    I checked and didn't find any way to specify the encoding used in the Shell or in the OS.
    The same code compiled on Linux or macOS works as expected when executed.
    [ Edited by Leo 08.07.2018 - 11:04 ]
  • »06.07.18 - 06:47
    Tcheko
    Posts: 543 from 2003/2/25
    Almost everything is running with ISO-8859-X or other 8 bit encoding for russian for example.
    You have to handle character encoding yourself before outputing anything to the shell. There is the charsets.library that offers facilities for handling conversion between encoding.
  • »06.07.18 - 07:17
    Jeckel
    Posts: 133 from 2007/3/11
    Linux is using UTF-8 system-wide as default charset, so you can directly print UTF-8 chars but you will have to do charset conversions for anything else.
    MorphOS (like AmigaOS) is using an 8-bit only charset (it is given by the keyboard preferences). If you want to print UTF-8 chars you will have to use the charset.library to convert from UTF-8 to "system" encoding (of course not all UTF-8 chars can be converted to an 8-bit charset).
  • »06.07.18 - 07:49
    Posts: 3311 from 2003/3/5
    Unless you've changed the SDK defaults, you'd be compiling this with gcc2.95.3 - try with gcc5 or 6.
  • »06.07.18 - 09:30
  • Leo
    Leo
    I am using cross-compilation and if I remember correctly it's something like gcc5. Does it change anything regarding encoding?
    What's the best practices for MorphOS (only) CLI apps that need to be localized: do people use charset library or do they use ISO?
    What happens with locale catalogs: what should catalogs .cd files be encoded in?
  • »06.07.18 - 10:13
    No, it does not change anything. Your app should come with English and ISO-8859-1 for the builtin defaults. Or you can use ObjectiveC and then UTF-8 comes for free.
    English/ISO-8859-1 for the built-in language and locale/catalogs for translations.
    The catalogs need to be encoded in ISO-8859-1 and .ct files encoded in the default ISO-8859-* associated with the catalog's language.
    Edit: I've misread your original post. You may not output UTF-8 text straight into the shell - that is not supported for compatibility reasons. In that case, either use charsets or Objective-C to output text in the native ISO codepage.
    [ Edited by jacadcaps 06.07.2018 - 08:22 ]
  • »06.07.18 - 10:19
  • Leo
    Leo
    Ok, that's what I thought.
    Where can I find some documentation on how to convert an UTF8 string to locale codepage using charsets.library?
  • »06.07.18 - 11:07
    Jeckel
    Autodocs of charsets.library are self-explanatory. :)
  • »06.07.18 - 11:36
  • Leo
    Leo
    Thank you for the answers. After some thoughts I'll go with the traditional way of doing things and will use ISO8859-1 as there is no good reason to use UTF8.
    I guess directly supporting UTF8 in the whole OS is not planned (because not really possible without loosing compatibility)?
    [ Edited by Leo 08.07.2018 - 11:05 ]
  • »08.07.18 - 09:03
    Tcheko
    Nothing is wired to support multibyte encoding in the operating system for legacy library calls. For example, all text related functions in graphics.library do not have a hint about text encoding.
  • »08.07.18 - 20:42
