E-UAE JIT overlay fix
    BSzili
    Posts: 570 from 2012/6/8
    I got hold of a patch that fixes the overlay support in E-UAE when AGP accelerated overlays are available. It turns this:
    into this:
    A couple of disclaimers:
    1) I'm not the author of the patch, thus I can't provide support for it.
    2) The sources of Fab's E-UAE port aren't available, it's applied the vanilla E-UAE JIT codebase.
    Now that I got those out of the way, here's the E-UAE JIT archive with the fixed "e-uae" executable:
    http://bszili.morphos.me/ports/E-UAE_1.0.0-JIT-ovl.lha
    You can find the patch itself on the E-UAE PowerPC JIT SF.net page:
    https://sourceforge.net/p/euaeppcjit/tickets/77/
  • »12.02.18 - 18:53
    waldiamiga
    Posts: 96 from 2007/7/25
    Yeeeeahhh. I'am testing! BSili thank you for sharing.
    MorphOS.pl
    Alienware 15 R3|WinUAE 5.x/AmigaOS4.1x & Icaros Desktop 2.x & QEmu 9.x.x
  • »12.02.18 - 19:28
    Jeckel
    Posts: 133 from 2007/3/11
    Good to know. :)
    FYI there is the same issue with MAME when using some ROMs (IIRC, DoDonPatchi has this issue).
  • »12.02.18 - 20:12
    Chain-Q
    Posts: 350 from 2003/10/12
    Indeed, MAME has the same issue, it never handles the now required overlay line modulo setting, it just assumes that the modulo equals the window with times bit per pixel, which is not (always) true any more.
    However, latest MorphOS MAME source doesn't seem to be available (it's not on Fab's site at least), so it's hard to provide a fixed build.
    [.Hosting AmigaSpirit.hu.]
  • »13.02.18 - 10:10
    BSzili
    AFAIK Fab said the sources of MAME 0.120 are lost, but I have no clue what happened to 0.148. Either way only version 0.113 is available.
  • »13.02.18 - 14:28
    peg4a
    Posts: 26 from 2003/4/15
    Thank you very much BSzili :) I was waiting for a fix, EUAE JIT is great in overlay :p
    Peg4A
    Powermac G5
    2,3 giga mono processor. HDD : 750 Go sata ATI 9800 XT 256 mo.
    Morphos 3.4 ;)
  • »04.03.18 - 08:48
    Korni
    Posts: 473 from 2006/2/23
    Non-overlay fix if you don't want to use a 15/16bit screen (if you don't have one it fails and opens a 640x480 screen) and don't want to pick a screenmode in requester everytime.
    I changed preferred depth to 32, 16, 15, 8 from 15, 16, 32, 8
    http://korni.ppa.pl/temp/E-UAE_1.0.0-JIT.lha.xz
  • »04.03.18 - 12:30
    Condor
    Posts: 100 from 2005/9/1
    @Korni
    OT:
    Can you fix bug in Chocolate-Strife.
    Doom, Hexen and Heretic version works fine, but Strife have problem with paths.
    Loading starts and then game exit with message ClearTmp: ./somethin error.
    I was try two verions of Strife data without luck.
    Thank You.
  • »05.03.18 - 08:37
    Korni
    Check if creating . directory helps.
  • »05.03.18 - 11:41
    Condor
    Thanks for your quick replay.
    I am on work now, but i think is asking for ./strsav6 dir or something like that.
    I have that dir (srtsav6 i think) but without "./"
    Will check when I get home. Thanks again.
  • »05.03.18 - 11:48
    BSzili
    Peg4A
    Great to hear it works for you! Cheers!
  • »05.03.18 - 13:21
    Condor
    @Korni
    This is error message in Chocolate-Strife: ClearTmp: Couldn't open dir ./strfsav6.ssg
    Dirs strfsav6.ssg and strfsav0.ssg I have in same game dir, but engine is looking unix like path.
    Thanks again.
  • »08.03.18 - 13:23
    Korni
    http://korni.ppa.pl/temp/chocolate-strife.xz
    Should work fine now.
  • »08.03.18 - 17:22
    Condor
    @Korni
    That was fast and it's run fine now. :)
    Thank you Korni for old cool game I can play now on MorphOs.
    Best regards
  • »08.03.18 - 18:08
    Korni
    @Condor
    Have fun!
  • »08.03.18 - 19:07
    Condor
    @Korni
    Another problem with strife:
    Couldn't read file savegames/strfsav0.ssg/\current
    Load/Save slots are always emty, even if i name and save the game.
    I try to use Quicksave and then quickload but this quit the game with this line above.
    Hope this help to find fix for this nice game.
  • »10.03.18 - 13:35
    Korni
    Sry for this. This time it should work hopefully. Redownload :).
  • »10.03.18 - 14:14
    Cool_amigaN
    Posts: 777 from 2011/11/30
    @ Korni / BSzili
    Thank you both! Strife works with latest chocolate upload and e-uae works on window mode with overlay :)
  • »11.03.18 - 18:20
    Condor
    @Korni
    Yes Strife is now ok. :)
    Thanks again.
  • »12.03.18 - 04:35
