[MUI] StringObject and cursor up/down key events
    r-tea
    Posts: 317 from 2005/3/27
    Hi guys.
    How to dectec cursor keys strikes from within MUI String object?
    Is there an easy way?
  • »13.07.17 - 18:02
    Posts: 2732 from 2003/2/24
    JavaScript? ;-)
  • »13.07.17 - 23:16
    Posts: 3336 from 2003/3/5
    Did you try checking for
    MUIKEY_UP
    MUIKEY_DOWN
  • »13.07.17 - 23:38
    r-tea
    MUIKEY_UP
    MUIKEY_DOWN
    No, looks like it's for building mcc's only.
  • »14.07.17 - 14:57
    Well, you need to sched a little bit more detail into what exactly is it that you are doing. Source code perhaps?
  • »14.07.17 - 15:49
    Tcheko
    Posts: 544 from 2003/2/25
    @r-tea, subclass the StringObject and add an event handler catching IDCMP_RAWKEY.
    See http://www.sasg.com/mui/autodocs/MUI_Window.html#MUIM_Window_AddEventHandler for the details.
    That way, you'll be able to see all keyboard events and catch UP/DOWN keys. If you want to eat the event (ie no further processing), the EventHandler method should return MUI_EventHandlerRC_Eat.
  • »14.07.17 - 15:51
    r-tea
    I don't need it anymore. Thanks anyway.
  • »14.08.17 - 11:55
