missing support for threads in c++11?
    Posts: 650 from 2004/4/15
    Is threading not support by g++ 5.3 on morphos?
    I get the following compiler error:
    lib/src/SDLView.cpp: In member function 'void exdevgfx::SDLView::run()':
    lib/src/SDLView.cpp:160:9: error: 'std::this_thread' has not been declared
    std::this_thread::sleep_for(msToWait);
    #include <thread> is not missing.
    On linux and mac os x everything is fine.
  • »19.02.17 - 10:07
    Posts: 3332 from 2003/3/5
    C++11 support is incomplete indeed.
  • »19.02.17 - 13:01
    For now I am using SDL_Delay. Will the c++11 support completed in near future?
  • »19.02.17 - 13:13
    Unless required by WebKit, it seems unlikely to happen.
  • »19.02.17 - 14:56
    ausPPC
    Posts: 543 from 2007/8/6
    I'm not entirely sure if this is close enough to what you want to do with threading but there's a fairly straight forward example of how to create a new process and have 'parent' and 'child' processes message back and forth in SDK:Examples/Misc/procmessages.c
  • »19.02.17 - 19:00
    thx ausPPC. But I want to use less system dependent functions as possible.
    C++11 defines threading and I thought the current SDK supports this standard.
  • »19.02.17 - 19:31
    CISC
    Posts: 619 from 2005/8/27
    There is limited threading support, I think however the problem is that sleep_for() requires nanosleep.
    - CISC
  • »20.02.17 - 06:10
    tolkien
    Posts: 578 from 2013/5/29
    So...is anyone updating webkit? :)
  • »20.02.17 - 18:19
    CISC
    Actually, I just checked and the reason is simply that the thread interface gets completely disabled since we only provide partial gthread support.
    - CISC
  • »22.02.17 - 17:52
