undefined reference to `DynLoadBase'
    deka
    Posts: 136 from 2013/2/12
    I'd like to create a program which uses dlopen/dlerror/dlsym/dlclose.
    I receive this message by linking.
    Which library do I have to link?
  • »24.01.17 - 11:21
    CISC
    Posts: 619 from 2005/8/27
    -ldl_shared
    - CISC
  • »24.01.17 - 11:43
    deka
    CISC wrote:
    -ldl_shared
    - CISC
    Thanx!
  • »24.01.17 - 11:48
    deka
    CISC wrote:
    -ldl_shared
    - CISC
    No such file or directory.
  • »24.01.17 - 17:14
    Henes
    Posts: 507 from 2003/6/14
    That would be -ldl but not sure it's part of the SDK.
  • »24.01.17 - 17:54
    CISC
    There's a couple of possibilities:
    1. It's only available when you build with -noixemul
    2. It's not included in the SDK at all for some reason
    The solution for 1 should be obvious, for 2; try building with -D__MORPHOS_SHAREDLIBS
    - CISC
  • »25.01.17 - 03:56
    deka
    @CISC:
    It is compiled with -noixemul and the -D option also doesn't help... :(
    Any idea?
    @Henes:
    "No such file or directory." for -ldl
  • »25.01.17 - 05:58
    Posts: 3300 from 2003/3/5
    Sorry, the lib was not part of the SDK - I've just fixed that though so it'll appear in the next one.
    Meanwhile, msg me with your email so I can send you the lib.
  • »26.01.17 - 02:04
    deka
    Ok... There isn't any urgent about it. ;)
    If the new SDK comes in the next couple of months, it is OK for me.
  • »26.01.17 - 05:50
