[AmigaE, MUI] Notifying Coloradjust object
    r-tea
    Posts: 317 from 2005/3/27
    How to notify Coloradjust Object properly to get proper response?
    I have tried all available InputMode values already: RelVerify, Toggle, Immediate.
    I set notification on Pressed attribute like this"
    domethod(ca,[MUIM_Notify, MUIA_Pressed, MUI_TRUE, MUIV_Notify_Self,2,MUIM_CallHook,get_colHook])
    The procedure installed as a hook looks like this:
    DEF get_colHook:hook
    PROC get_col()
    get(ca,MUIA_Coloradjust_RGB,[col])
    StringF(rgb,'zh[8]',col)
    set(str_hex, MUIA_String_Contents, rgb)
    set(str_dec, MUIA_String_Contents, rgb)
    WriteF(rgb, 'dn')
    ENDPROC
    And inside the main() procedure:
    .Code:
     installhook(get_colHook, {get_col})
    To simplify things I made all variables global. And everything would be ok for me except the Coloradjust gadget response only when one clicks outside the triangle and outside the thick circle. When I click inside the triangle or onto the thick color ring the notification seems to not work.
  • »14.01.17 - 20:06
    Leif
    Posts: 111 from 2006/5/31
    PROC get_col()
    WriteF(rgb, 'dn')
    ENDPROC
    .Code:
    should be
    get(ca,MUIA_Coloradjust_RGB,{col})
    doh
    /Leif
    [ Edited by Leif 15.01.2017 - 13:49 ]
  • »15.01.17 - 11:28
    igracki
    Posts: 469 from 2003/2/24
    Why don't you create a notify on MUIA_ColorAdjust_RGB?
    domethod(ca, [MUIM_Notify, MUIA_ColorAdjust_RGB, MUIV_EveryTime, MUIV_Notify_Self, 2, MUIM_CallHook, get_colHook])
    Also better use subclassing, then you can use own methods instead of hooks.
  • »15.01.17 - 12:01
    Posts: 1092 from 2004/9/23
    Yeah, hooks are more or less obsolete. There were a good idea for hooking into system libraries, but in MUI they were always a bad solution.
    There are a few classes which are not supporting methods, but generally you can use notifications.
    Same goes for lists. Avoid hooks for construct, destruct, sort and co. Just use the methods provided by mui. It is much less work as you dont need to deal with all the shit hooks and code jumps deliver. Just a clean method you receive when something happens and you are done.
    Of course this means subclassing, but it is not as bad as it sounds. once you have a proper source file to subclass something, you can simply use it everywhere and it is a nobrainer.
    Also if you create a fancy subclass in application one you can simply use that as often as you want and even copy it over to other applications of yours.
    Just take a look onto the system settings. The main settings application is just a pile of icons or a list with the settings panels. The panels itself are separate binaries and even inside those panels gui elements come from additional files like the blankers or the usb hardware driver.
    Those panels are also used during system installation as well, so going the mui sub class way is the smart way, even if it at first takes some time to understand.
  • »15.01.17 - 13:08
    r-tea
    Thanks. Now it works with the whole gadget :-)
    But hooks are better than putting all the handling stuff into MUI's main loop in SELECT CASE ENDSELECT block, and that was the way I did in my very first E/MUI programming attempts :-)
    There's still something wrong in my code. Now the hook is executed each time the color changes, but it allways returns the same color value.
    And I forgot to mention now I use ECX to make use of your Lamp module.
  • »15.01.17 - 20:26
    igracki
    [quote]r-tea wrote:
    [quote]igracki wrote:
    Also better use subclassing, then you can use own methods instead of hooks.[/quote]
    [/quote][/quote]
    When using subclassing, the main MUI "loop" looks like this:
    DoMethod(app, MUIM_Application_Run)
    Here is an example of how a MUI program in ecx looks like (with my own mui extensions):
    The main source:
    OPT PREPROCESS, STACK = 32678 -> SEHR WICHTIG! Sonst gibts Hits, wenn AboutMUI oder meine AboutBox offen war!!!
    OPT EXENAME = 'ofdbMUI'
    MODULE '*mods/myApp' -> APP_NAME, APP_AUTHOR, APP_VER
    MODULE 'dos/dos', 'dos/rdargs'
    MODULE 'muimaster', 'new/muimaster'
    MODULE 'utility/tagitem', 'amigalib/boopsi' -> for doSuperMethodA
    -> my own public modules
    MODULE 'libMUI', 'mccSupport', 'muiSupport'
    MODULE 'myDebug', 'ezRequester'
    MODULE '*mods/lstMovies_mcc', '*mods/winMain_mcc', '*mods/app_mcc'
    -> shell args stuff
    #define ARGS_TEMPLATE 'E-Source/M,VERBOSE/S'
    OBJECT myArgs
    srcs: PTR TO LONG -> the source file(s)
    verbose
    ENDOBJECT
    VERBOSE MACRO IF args.verbose = DOSTRUE THEN 1
    DEF
    rda = NIL: PTR TO rdargs, args: PTR TO myArgs
    PROC main() HANDLE
    DEF app=NIL
    NEW args
    IFN rda := ReadArgs(ARGS_TEMPLATE, args, NIL) THEN Raise("ARGS")
    OpenMuiMasterLib()
    InitClasses 3
    AddNewClass MyApp
    AddNewClass WinMain
    AddNewClass LstMovies
    IF ClassesSetup()
    app := MyAppObject, End
    IFN app THEN Raise("APP")
    set(winMain, MUIA_Window_Open, MUI_TRUE)
    set(winMain, MUIA_Window_Open, FALSE)
    ELSE
    PrintF('ClassesSetup() failed!!!n')
    ENDIF
    EXCEPT DO
    SELECT exception
    CASE "ARGS"; DOSError(NIL)
    CASE "APP" ; PrintF('ERROR: Failed to create Application!n')
    ENDSELECT
    IF rda THEN FreeArgs(rda)
    END args
    IF app THEN MUI_DisposeObject(app)
    ClassesCleanup()
    CloseMuiMasterLib()
    ENDPROC
    In this module I put all methods of all my subclasses, so I need to import only this module:
    OPT MODULE, MODNAME='myApp'
    OPT PREPROCESS, EXPORT
    MODULE 'utility/tagitem', 'intuition/classes', 'workbench/workbench'
    CONST MUISN_IGRACKI = <put your own mui serial here!>
    CONST TAGBASE_IGRACKI = TAG_USER OR (MUISN_IGRACKI SHL 16)
    -> change these 3 defines
    #define APP_VER '1.0'
    #define APP_NAME 'ofdbMUI' -> CHANGEME
    #define APP_AUTHOR 'Thomas Igracki' -> CHANGEME
    #define APP_VERSION '$VER: ' + APP_NAME + '_' + __TARGET__ + ' ' + APP_VER + ' ' + __AMIGADATE__ + ' by ' + APP_AUTHOR + ''
    #fmtstr APP_COMPILED 'Compiled: s s for s - ECX vs' __DATE__ __TIME__ __TARGET__ ECX_VERSION
    #define APP_COPYRIGHT '(c) 2014'
    #define DOSError(str) PrintFault(IoErr(), IF str THEN str ELSE APP_NAME)
    -> Now all attributes and methods of ALL my subclasses, so every module can access them
    ->>> app_mcc.e: Attributes/Methods <<<<<<<<<<<<<<
    ENUM
    MA_MyApp_Base = TAGBASE_IGRACKI
    ENUM
    MM_MyApp_Base = TAGBASE_IGRACKI,
    MM_MyApp_ShowAbout
    MOBJECT MP_MyApp_ShowAbout, mp_MyApp_ShowAbout
    methodID: LONG
    ENDOBJECT
    ->>> winMain_mcc.e Attributes/Methods <<<<<<<<<<<
    ENUM
    MA_WinMain_Base = TAGBASE_IGRACKI
    ENUM
    MM_WinMain_Base = TAGBASE_IGRACKI,
    MM_WinMain_MenuAction,
    MM_WinMain_Search
    MOBJECT MP_WinMain_Search, mp_WinMain_Search
    methodID: LONG
    ENDOBJECT
    MOBJECT MP_WinMain_MenuAction, mp_WinMain_MenuAction
    methodID: LONG
    itemID : LONG
    ENDOBJECT
    ->>> lstMovies_mcc.e Attributes/Methods <<<<<<<<
    ENUM
    MA_LstMovies_Base = TAGBASE_IGRACKI
    ENUM
    MM_LstMovies_Base = TAGBASE_IGRACKI,
    MM_LstMovies_Search
    MOBJECT MP_LstMovies_Search, mp_LstMovies_Search
    methodID: LONG
    forStr: PTR TO CHAR
    ENDOBJECT
    And a subclass, winMain_mcc.e:
    OPT PREPROCESS, MODULE, MODNAME='winMain_mcc'
    MODULE 'exec/libraries', 'exec/lists',
    'mui/muicustomclass', 'muimaster','new/muimaster',
    'intuition/classes','intuition/classusr','intuition/screens','intuition/intuition',
    'utility', 'utility/tagitem',
    'workbench/startup', 'workbench/workbench',
    'amigalib/boopsi', ->
    'dos/dostags'
    ->MODULE 'libraries/asl'
    MODULE 'mui/StringHistory', 'mui/Lamp'
    -> my modules
    MODULE 'myDebug', 'libMUI', 'mccSupport', 'muiSupport', 'MUInames', 'ezRequester'
    MODULE '*myApp', '*lstMovies_mcc'
    /* Here is the beginning of our new class... */
    ** This is the instance data for our custom class.
    DEF mcc = NIL: PTR TO mui_customclass
    OBJECT myData
    strip
    strSearch
    butSearch
    lstMovies
    lamp
    ENDOBJECT
    -> the attributes/methods of my subclass are defined in myApp.e, so all modules can access them!
    -> menu ids
    ENUM
    MEN_PROJECT = 0,
    MEN_PROJECT_ABOUT,
    MEN_PROJECT_ABOUTMUI,
    MEN_PROJECT_QUIT
    -> this macro creates the needed procs/defines:
    -> mccCreateXXX(), mccDeleteXXX(), XXXObject
    DEC_SUBCLASS MUIC_Window, WinMain
    PROC_MNEW winMain
    DEF nd: myData
    D('WinMain: nd = 0x%lxn', nd)
    ->nd := 0
    -> IF (obj := doSuperNewA(cl, obj, [
    IF (obj := DOSUPERNEW(
    MUIA_Window_ID, "MAIN",
    MUIA_Window_Title, APP_NAME,
    MUIA_Window_AppWindow, MUI_TRUE,
    MUIA_Window_Menustrip, nd.strip := MenustripObject,
    Child, MenuObjectT('Project'),
    Child, MyMenuitem('?About...', MEN_PROJECT_ABOUT),
    Child, MyMenuitem('About MUI...', MEN_PROJECT_ABOUTMUI),
    Child, MyMenuitem(NM_BARLABEL, 0),
    Child, MyMenuitem('QQuit', MEN_PROJECT_QUIT),
    End,
    End,
    WindowContents, VGroup,
    Child, HGroup,
    Child, nd.lamp := LampObject, MUIA_Lamp_Type,MUIV_Lamp_Type_Gigantic, End,
    Child, Label2('_Search'),
    Child, nd.strSearch := KeyString('', 128, "s"),
    End,
    Child, nd.butSearch := MakeButton('S_earch'),
    Child, VGroup,
    GroupFrameT('Movies'),
    Child, nd.lstMovies := LstMoviesObject,
    End,
    End,
    End,
    TAG_MORE, INIT_TAGS
    -> DDELAY(2)
    D('WinMain: obj = 0x%lxn', obj)
    GETDATA -> data := INST_DATA(cl, obj)
    COPYDATA -> copies contents of 'nd' to 'data'
    Notify(doMethodA(data.strip, [MUIM_FindUData, MEN_PROJECT_ABOUTMUI]),
    MUIA_Menuitem_Trigger, MUIV_EveryTime, MUIV_Notify_Application, 2, MUIM_Application_AboutMUI, obj)
    Notify(obj, MUIA_Window_MenuAction,MUIV_EveryTime, obj, 2, MM_WinMain_MenuAction, MUIV_TriggerValue)
    NotifyBut(data.butSearch, obj, 1, MM_WinMain_Search)
    ENDIF
    ENDPROC_MNEW winMain
    PROC_MSET winMain
    ->D('data = 0x%lx, msg = 0x%lxn', data, msg)
    FORTAG INIT_TAGS
    CASE MUIA_Window_Open
    DDELAY(2)
    DOSUPER
    D('in MUIA_Window_Open, TI_DATA =%ldn', TI_DATA)
    IF TI_DATA = MUI_TRUE
    DDELAY(3)
    ENDIF
    DEFAULT
    ->DebugF('tag.tag = 0x%lx(%s)n', tag.tag, MID2STR(tag.tag))
    NEXTTAG
    ENDPROC_MSET winMain
    PROC_METHOD MM_WinMain_MenuAction, mp_WinMain_MenuAction
    GETDATA -> data := INSTDATA(cl, obj)
    SELECT msg.itemID
    CASE MEN_PROJECT_ABOUT; DoMethod(_app(obj), MM_MyApp_ShowAbout)
    ->CASE MEN_PROJECT_ABOUTMUI; doMethodA(_app(obj), [MUIM_Application_AboutMUI, obj, 0])
    CASE MEN_PROJECT_QUIT; setMuiTrue(obj, MUIA_Window_CloseRequest)
    DEFAULT
    DebugF('itemID = %ldn', msg.itemID)
    ENDSELECT
    ENDPROC_METHOD MM_WinMain_MenuAction, 0
    PROC_METHOD MM_WinMain_Search, MP_WinMain_Search
    ->Okay('Hallo!')
    set(data.lamp, MUIA_Lamp_Color, MUIV_Lamp_Color_Connecting)
    Delay(20)
    set(data.lamp, MUIA_Lamp_Color, MUIV_Lamp_Color_LoadingData)
    Delay(20)
    set(data.lamp, MUIA_Lamp_Color, MUIV_Lamp_Color_Ok)
    Delay(20)
    DoMethod(data.lstMovies, MM_LstMovies_Search, xget(data.strSearch, MUIA_String_Contents))
    ENDPROC_METHOD MM_WinMain_Search, 0
    ** Here comes the dispatcher for our custom class.
    ** Unknown/unused methods are passed to the superclass immediately.
    DISPATCHER_TABLE
    DEC_NEW
    DEC_SET
    DEC_METHOD MM_WinMain_MenuAction
    DEC_METHOD MM_WinMain_Search
    DEFAULT
    D('msg.methodid = 0x%lxn', msg.methodid)
    DISPATCHER_TABLE_END
  • »16.01.17 - 13:04
