TinyGL
    tolkien
    Posts: 585 from 2013/5/29
    I want to toy with TinyGL. There are a lot of info about OpenGL but I don´t know in which version TinyGL is based on. OGL1? 2?
    I don´t want to follow unsupported standards. Show me some lights mates as I have no much idea.
    Thanks.
  • »26.10.15 - 19:00
    BSzili
    Posts: 570 from 2012/6/8
    It's a subset of 1.x.
  • »26.10.15 - 19:39
    tolkien
    Ok. So I'll have to look for very old tutorials. I have tried to download the TinyGL documentation but I failed.
    Thanks BSzili.
  • »26.10.15 - 19:56
    deka
    Posts: 136 from 2013/2/12
    Hi!
    I'm working on an OpenGL photo viewer app and experienced a serious problem:
    If I use bigger than 4096x4096 textures, the 1:1 view of the texture becomes very undetailed...
    With smaller textures, it looks fine.
    Is it possible to solve this problem somehow?
  • »13.06.16 - 05:45
    deka
    One more question: Are the rectangle or NPOT textures supported?
    Could be this the solution?
    [ Edited by deka 13.06.2016 - 13:05 ]
  • »13.06.16 - 06:55
  • ASiegel
    Posts: 1397 from 2003/2/15
    What graphics chip do you use for testing? GPUs tend to have maximum texture size limitations and the downsizing of your textures (undetailed representation) might be the result of a technical "fallback".
  • »13.06.16 - 07:27
    deka
    My computer is a PB 1.67 (R300).
    [ Edited by deka 13.06.2016 - 14:25 ]
  • »13.06.16 - 08:23
  • ASiegel
    So, Mobility Radeon 9700 with maximum viewport size of 4096 x 4096 and maximum texture size of 2048 x 2048 (Source: Link).
  • »13.06.16 - 09:15
    deka
    Sad to see that... :(
    Thank you for your help!
  • »13.06.16 - 10:09
    Posts: 2732 from 2003/2/24
    Why do you need such large resolution? Maybe you should consider making your application tolerant for lower end HW? I believe the number of potential users of your application that has a 4k MorphOS setup can be counted on your right hands fingers anyway... ;-)
  • »13.06.16 - 13:24
    deka
    @takemehomegrandma:
    This will be a photo viewer app and I think it is an important feature to show the pic in 100%/200% zoom. This huge resolution is not for the 4k displays (if I understood you well). ;)
  • »13.06.16 - 13:34
  • ASiegel
    Have you considered splitting large images into multiple textures (image tiling) that are, say, 512 x 512 each?
  • »14.06.16 - 06:38
    deka
    Yeah... That was the first idea and also implemented this. It worked, but had two problems:
    - Sometimes the texture edges were visible. It wasn't smooth enough.
    - The texture creation took much more time: it took about 10-15 secs instead of the current 2 secs.
    I was considering more solution:
    - Tried the Rectangle texture today, but it seems that it is not supported by TinyGL.
    - My second idea is to use NPOT textures, but probably the 4096x4096 limit is there too. Will see it...
    - A software prescaler. This solution seems to be the most realistic. Maybe, if using NPOT textures makes me possible (on R300) to show wider, than 4096 pixel pictures, the software scaler should be there, because R200 owners will have more limitations.
    Also, should be send a request to the video driver to get the max. texture size, because the used algorhytm could change depending the existing video HW. (The bigger video cards have 16kx16k texture limit.)
  • »14.06.16 - 07:00
  • ASiegel
    Do you remember what texture filtering type you used? Did changing it improve anything?
    Absolutely.
  • »14.06.16 - 12:05
    deka
    Not really...
    As I remember, it was very casual when the effect came or not. I bet, it was a floating point number rounding problem...
    The most painfull thing was the long texture binding time.
    I'm sure, it is more cleaner solution to have one bigger texture, even if some software scaling magic is needed.
    The implementation is also closer for newer and for older video HW.
    [ Edited by deka 14.06.2016 - 18:45 ]
  • »14.06.16 - 12:41
