DoMethod() vs DoMethodA()
    ausPPC
    Posts: 543 from 2007/8/6
    Does anyone know the equivalent function call to DoMethodA() for the following?
    Object *App, *Win;
    DoMethod(Win, MUIM_Notify, MUIA_Window_CloseRequest, TRUE, App, 2,
    MUIM_Application_ReturnID, MUIV_Application_ReturnID_Quit);
  • »12.03.16 - 01:01
    r-tea
    Posts: 308 from 2005/3/27
    Object *App, *Win;
    Hope it helps. Here's the AmigaE style of MUI method call.
            doMethodA(window, [MUIM_Notify, MUIA_Window_CloseRequest, MUI_TRUE,
    app, 2, MUIM_Application_ReturnID, MUIV_Application_ReturnID_Quit])
    I miss draggable screens... and do you? I know I'm in a minority unfortunately.
  • »12.03.16 - 05:46
    ausPPC
    Thank you, I can see some similarity to what I just found with objdump and a dummy program with an empty call to DoMethodA(). As it turned out, most of the problem I was having came from a messed up pointer to that not-quite-a-taglist given as the second parameter.
    Meaningful documentation would also help. ;)
  • »12.03.16 - 07:23
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    Object *App, *Win;
    Try this:
    tag *Tag: = { MUIM_Notify, MUIA_Window_CloseRequest, TRUE, App, 2,MUIM_Application_ReturnID, MUIV_Application_ReturnID_Quit,TAG_END};
    DoMethodA(Win,Tag);
  • »12.03.16 - 08:19
