MUI general while() loop issue
    r-tea
    Posts: 317 from 2005/3/27
    I tried to make a simple digital clock using MUI window, but the result has a strange issue. The method SetAsString, which updates the text gadget displaying clock digits, stops updating right after I deactivate the window and remove the mouse pointer from over the window.
    Below is part of the loop.
    		while (running)
    time(&ptr_sec); //// gets data for digital clock
    h = localtime(&ptr_sec)->tm_hour;
    m = localtime(&ptr_sec)->tm_min;
    s = localtime(&ptr_sec)->tm_sec;
    DoMethod(tx_clock, MUIM_SetAsString, MUIA_Text_Contents, "%02d:%02d:%02d", h, m, s);
  • »28.02.16 - 17:38
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    		while (running)
    At First: Never Write anything in this Loop.
    Use notyfies .
    If you wish to build a clock , use window events and a trigger .
    Read the mui Tutorials in the Sdk.
  • »28.02.16 - 18:24
    Tcheko
    Posts: 544 from 2003/2/25
    You should give a look at MUI example InputTimer.c in the SDK. It is located in SDK:Examples/MUI/.
    This one is a good start for doing what you're looking for.
    And never tweak the MUI event loop (unless you need to handle signal/msgport outside of MUI).
  • »28.02.16 - 19:02
    r-tea
    I have the latest SDK, but there's no such an example you mentioned about. There is InputHandler.c instead. Is this the one?
    [ Edited by r-tea 28.02.2016 - 22:34 ]
  • »28.02.16 - 19:34
