undefined reference to "select"
    ciVic
    Posts: 45 from 2013/6/2
    Hi all,
    I'm trying to port a classic prog to MorphOS that uses curl. But on MorphOS I get the linker error:
    /usr/local/lib/libcurl.a(select.o): In function `Curl_poll':
    select.o(.text+0x780): undefined reference to `select'
    I cannot find a lib that exports that function on MorphOS. Under OS 3.1 I linked against a libamiga.a that does not exists on MorphOS, maybe that's why it works on OS 3.1 and not on MorphOS. Anybody has an idea? Thx!
  • »22.06.13 - 09:54
    boot_wb
    Posts: 874 from 2007/4/9
    ciVic wrote:
    Hi all,
    If you don't get an answer, try the #morphos channel on IRC. It tends to be a bit quicker for coding support.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »22.06.13 - 10:14
    BSzili
    Posts: 570 from 2012/6/8
    You are using some screwed up (maybe ixemul?) version of curl, because that function should be defined to WaitSelect in bsdsocket.library.
  • »22.06.13 - 10:59
    ciVic
    I've tried 7.12.3 and 7.16.0 from Aminet for MorphOS. Where can I get a better version?
  • »22.06.13 - 12:36
    BSzili
    I haven't tried those. What are you trying to compile? I have a fairly recent version of cURL without SSL support.
  • »22.06.13 - 15:29
    ciVic
    I want to port twittAmiga. It did not need SSL in the past, but Twitter has updated the API, now we need SSL (so currently twittAmiga do not work). I am now able to compile cURL with SSL, but only with ixemul (at least that works with twittAmiga). The original makefiles for Amiga do not work anymore (or do not work on MorphOS). Maybe I will check that later.
  • »23.06.13 - 06:53
    Posts: 610 from 2003/4/11
    You might try this if nothing else works ...
    #ifdef __MORPHOS__
    #include <proto/socket.h>
    static int __inline
    select(int nfds, fd_set *readfds, fd_set *writefds, fd_set *exeptfds,
    struct timeval *timeout)
    return WaitSelect(nfds, readfds, writefds, exeptfds, timeout, NULL);
    #endif
  • »23.06.13 - 08:22
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    I could also supply cURL 7.27.x or so. It's heavily tested, since it's used by Odyssey. ;)
  • »23.06.13 - 09:59
    ciVic
    The macro sound like an easy solution. But a good lib sounds also good. Via mail?
  • »23.06.13 - 17:05
    Posts: 2 from 2014/10/10
    Hi!I'm having a similar problem using curl 7.16 from Aminet.
    Can anyone share a working library with me?
    Thanks in advance
  • »10.10.14 - 19:45
    ciVic
    An old thread but since some new issues I would love to get that version.
  • »20.06.15 - 14:03
    asrael22
    Posts: 451 from 2014/6/11
    Hi.
    In which way is cURL used by Odyssey?
    The executable or a library of some kind?
    Manfred
  • »24.02.16 - 05:43
    Posts: 12547 from 2003/5/22
    > In which way is cURL used by Odyssey? The executable or a library of some kind?
    libcurl compiled into the Odyssey executable.
  • »24.02.16 - 06:04
    asrael22
    OK, is this libcurl compilation freely available?
    I've tried compiling a recent version of libcurl but failed so far.
    Manfred
  • »24.02.16 - 06:30
    There are diffs for versions 7.28.1 and 7.34.0: http://fabportnawak.free.fr/owb/src/
  • »24.02.16 - 07:18
