Suggestions for Unicode
    asrael22
    Posts: 451 from 2014/6/11
    Hi.
    How far is the unicode support in MorphOS?
    What are the suggestions to deal with unicode texts?
    Would http://aminet.net/package/util/libs/UniLibDev be an option?
    Manfred
  • »09.02.16 - 08:06
    Posts: 1521 from 2003/2/24
    MorphOS has Unicode support through locale.library and charsets.library. Keymaps and Intuition support Unicode for the input. Multiview can display Unicode text and AmigaGuide files.
  • »09.02.16 - 08:43
    asrael22
    OK. So if I were to build an application that deals a lot with UTF8 encoded texts.
    Could I use system resources to load and display (MUI) those?
    Manfred
    [ Edited by asrael22 09.02.2016 - 12:12 ]
  • »09.02.16 - 08:52
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    Ährm... AmigaGuide can't display chinese unicode text files.
    The charsets.library can't decode all UTF- 32 chars (japanese, korean, chinese, arab and so on.)
    The only piece of software thats handle correct Unicode is the clipboard.
    I know. The charsets.library docde only to local charsets, but thats not full Unicode handling.
    The only lib to decode and display full unicode is cairo.library.
  • »09.02.16 - 16:50
    pegasos-sigi2
    Manfred
    Calimero can load UTF-8 Text (my own software).
  • »09.02.16 - 16:54
    Nadir
    Posts: 178 from 2003/3/17
    Scintilla (and therefore Scribble) supports unicode when using TTEngine for rendering (that's an option in the settings). Unfortunately, there is no support for glyph substitution so it might not be completely perfect but it does work for common cases at least.
  • »09.02.16 - 17:50
    asrael22
    Manfred
    Nice, how do you do it?
    Manfred
  • »09.02.16 - 18:47
    asrael22
    So, it's required some use fonts that can actually display unicode.
    What about reading from file? I read into a char array, what di I do with it to be treated as unicode text?
    Manfred
  • »09.02.16 - 18:48
    Posts: 2730 from 2003/2/24
    The charsets.library can't decode all UTF- 32 chars (japanese, korean, chinese, arab and so on).
    Neither emojis AFAIK (and there is no support for color fonts AFAIK which would be nice in emoji contexts). A lot of texting and even writing takes place on phones or tablets today, using e-mail applications, chat applications, or even text documents. And people use emojis! An e-mail sent from one iPad to another will properly display any emojis inside it, but open up the same mail on MorphOS, what will you see?
    So when discussing future unicode support, please don't forget the emojis! 😉👍 (<- I put two of them right there!)
    http://apps.timwhitlock.info/emoji/tables/unicode
    https://en.m.wikipedia.org/wiki/Apple_Color_Emoji
  • »09.02.16 - 20:45
    @asrael22
    MUI has no Unicode support so you can only use UTF8 encoded text through your MUI custom class you write for your application. For example while Odyssey Web Browser and Multiview can display Unicode text this is limited to the text display area only. If the web site title has code points not supported by local codepage you just get question marks to OWB titlebar.
    The built-in graphics.library/Text() can't render Unicode glyphs so you have to use freetype.library or ttengine.library to render Unicode.
    I have not tried (I think I have tried only Japanese) but the text rendering part is the problem.
    Which is also part of the OS. There is also iconv.library which provides more encodings than charsets.library (but at the expense of bigger memory footprint).
    It is also possible to create Cairo.mcc...
  • »10.02.16 - 05:35
    asrael22
    OK, if charsets.library can decode UTF-8 chars then that should be fine.
    I don't think I'm dealing with any UTF-32 stuff.
    Manfred
  • »10.02.16 - 13:45
    asrael22
    Is it possible to embed a MultiView component into an application?
    Manfred
  • »10.02.16 - 13:54
    Charsets.library can convert UTF-8 to an OS supported 8-bit charset or to UTF-16/32 respectively. You find supported charsets from libraries/charsets.h header.
  • »10.02.16 - 14:24
    Unfortunately no. Multiview.mcc has been planned but that plan has existed five years now and it still does not exist...
  • »10.02.16 - 14:25
    Nadir
    However, you can embed a scintilla.mcc view that will allow you to display Unicode text easily. All the material, including amigaguide docs, are in the SDK. You just need to pass the text to scintilla and set the rendering engine to TTEngine as described in the docs. If you don't want editing, then make the view read-only.
    Nicholai
  • »10.02.16 - 15:28
    Nadir
    [ Edited by Nadir 10.02.2016 - 20:05 ]
  • »10.02.16 - 15:28
    Nadir
  • »10.02.16 - 15:28
    Read into char array, then load a font and render text using TTEngine. IIRC TTEngine accepts UTF-8 but check this from the docs first. TTEngine is bit clumsy but can render Unicode glyphs in Amiga way.
  • »10.02.16 - 18:55
    Nadir
    Yes, UTF8 works fine with TTEngine, that's what I use in Scribble/Scintilla. There are some limitations in both the design and the features of that library but it's the best we have for rendering at the moment without going too deep into Linux domains
  • »11.02.16 - 00:19
    asrael22
    Thanks, that's great to know.
    I'll give this a try.
    Manfred
  • »11.02.16 - 06:09
    Cool_amigaN
    Posts: 777 from 2011/11/30
    I have properly displayed Greek characters only on MPlayer (as subtitles), on OWB partially (only when writing on forums/googling but not displaying properly inherited menus from forums/site news) and on Calimero (read/write). I would love to know whether there is a solution for OWB which is a lot annoying (can't navigate easily).
  • »11.02.16 - 07:53
    pegasos-sigi2
    Install the font "Arial Unicode MS" from Windows. Thats a full size Unicode font.
    Then OWB displays all languages "Greek, Chinese, Japanese, Korean and so on...) And Calimero, too ;-)
  • »12.02.16 - 14:42
    Cool_amigaN
    @pegasos-sigi2
    Hey, thanks for your suggestion. I downloaded the font but it seems that's almost 23MB, wtf, is this correct? After rebooting, OWB re-initialized fonts but yet again, the same problem occurs. I have also placed encoding to ISO 8859-7 and selected in every category within OWB Arial unicode MS as default font, but it is still a no go. Any ideas?
  • »15.02.16 - 12:51
