Posts: 650 from 2004/4/15
just tested a very small example:
#include <iostream>
#include <GL/gl.h>
#include <GL/glut.h>
using namespace std;
class GlutView {
public:
GlutView() {
glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB | GLUT_DEPTH);
glutInitWindowSize(640, 480);
glutInitWindowPosition(0, 0);
glutCreateWindow("Test");
glutDisplayFunc(GlutView::display_);
glutKeyboardFunc(GlutView::keyPressedEvent_);
glutSpecialFunc(GlutView::specialKeyPressedEvent_);
glutMainLoop();
static void display_() {
glClear(GL_COLOR_BUFFER_BIT);
glutWireTeapot(0.5);
glutSwapBuffers();
static void keyPressedEvent_(unsigned char key, int x, int y) {
cout << "keyPressedEvent_: key=" << (int) key << ", x=" << x << ", y=" << y << endl;
static void specialKeyPressedEvent_(int key, int x, int y) {
cout << "keyPressedEvent_: key=" << key << ", x=" << x << ", y=" << y << endl;
int main(int argc, char **argv) {
glutInit(&argc, argv);
GlutView v;
return 0;
compiled with: g++ TestGlut.cpp -std=c++11 -O0 -noixemul -I lib/include -lm -lGl -lglut
It works well!
In my project I do some more things (glut timer and idle function).
I will check if it makes something strange.
Good to know that the basics are working well. I will go on look for the reason
If I know what's going wrong I will reply here!
