Python, how low-level can it be?
    asrael22
    Posts: 453 from 2014/6/11
    Hi.
    I'd be interested in using the Python language.
    For what can it be used?
    Can it open libraries and use them? Or use the serial port, etc?
    Manfred
  • »06.01.16 - 17:23
    BSzili
    Posts: 570 from 2012/6/8
    You can access libraries, but first you have to create Python bindings for them.
  • »06.01.16 - 19:30
