Which version control do you use?
    asrael22
    Posts: 451 from 2014/6/11
    Hi.
    I'd like to use some version control system to share development files between MorphOS, AROS, AmigaOS, etc.
    AmigaOS (UAE emulated) could use the something from the host system.
    I've tried git-1.6.0.2 found on MorphOS files but for some reason pull doesn't work.
    What do you use?
    Manfred
  • »01.09.15 - 08:12
    Posts: 1092 from 2004/9/23
    What do you use?
    I use SVN.. My Pegasos2 with MorphOS acts as my SVN server, while all other systems are used for development.
  • »01.09.15 - 09:41
    asrael22
    Subversion. Yeah, why not. It's an option.
    What about mercurial, it's available as well. Does it work?
    Manfred
  • »01.09.15 - 12:05
    Posts: 650 from 2004/4/15
    MorphOs => svn
    Other => git, svn
  • »01.09.15 - 13:39
    rlitt01
    Posts: 43 from 2015/7/25
    Personally I use git. But, svn has better and easier revision history control for bigger projects. Sucks that google code closed. All that free space to host your project. Not a fan of sourceforge "sleazeware", even though they use svn.
    Powermac G5(A1047) 2.3GHz Registered MorphOS
    Powerbook G4 PowerBook5,8 1.6GHz Registered MorphOS
    Powermac G5(A1047) 2.0GHz Registered MorphOS
    Icaros Desktop 3.0GHz
  • »01.09.15 - 13:48
