MUI MUIA_list_DoubleClick
    tolkien
    Posts: 572 from 2013/5/29
    Hello mates. Noob MUI code question.
    Is there an example of how to use muía_list_DoubleClick?
    I try to use notify and muim_application_returnid in my list object but seems never works.
  • »07.08.15 - 12:26
    Posts: 2564 from 2003/2/24
    	DoMethod(data->class_list,MUIM_Notify,MUIA_List_DoubleClick,MUIV_EveryTime,obj,1,MM_BaseClassPopup_Selected);
    Works here (tm)
    And try to avoid MUIM_Application_ReturnID it's ad coding practice.
  • »07.08.15 - 14:41
    Posts: 1090 from 2004/9/23
    Using returnid is some old fashion first generation mui stuff and should only be used on the appilcation object with MUIV_Application_ReturnID_Quit.
    There is more or less no other reason to use it at all.
    Since i assume you are not quitting the application by double clicking a mui list, i suggest to use real methods in that case, as subclassing and adding own methods is the official way to go.
    [ Edited by geit 07.08.2015 - 17:50 ]
  • »07.08.15 - 14:45
    tolkien
    Hello!
    I know doing returnID is old and dirty but as I have said I'm new doing MUI stuff and there are a few things that don't understand as is subclassing.
    I'm in the process of reading and trying but seriously, Amiga community needs update coding info to get newer coders.
    I'll read again khrashan's info about subclassing and look for add new methods.
    Thanks for the help mates!
    [ Edited by tolkien 07.08.2015 - 18:41 ]
  • »07.08.15 - 15:40
    Krashan
    Posts: 1107 from 2003/6/11
    Some more precise suggestions would be more useful.
  • »10.08.15 - 02:16
    tolkien
    Some of my suggestions are equal to the naTmeg ones in
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=11301&forum=3
    but will try to elaborate them when I can.
  • »11.08.15 - 18:21
    r-tea
    Posts: 317 from 2005/3/27
    tolkien wrote:
    Hello!
    I pretty understand you, 'cause I'm noob programmer as well and I use odd and dirty MUI app style .
    Years ago I did a trivial GUI for Arc64 (C64 disk images manipulating tool), and now I digged out my source code.
    DoMethod(lister_r, MUIM_Notify, MUIA_Listview_DoubleClick, TRUE, app, 2, MUIM_Application_ReturnID, ID_LRDBLCLICK);
    All IDs I handle in main SWITCH loop and it works.
    But don't use this style if your project become big.
  • »11.08.15 - 20:13
    tolkien
    That is what I do but with muía_list_DoubleClick but with no response. I'll try to create a listview. Thanks mate!
    [ Edited by tolkien 12.08.2015 - 22:12 ]
  • »12.08.15 - 10:24
