The irony... Rosetta not translating...
    ausPPC
    Posts: 543 from 2007/8/6
    Is this a doomed example or is there a simple fix to produce the desired output?
    https://rosettacode.org/wiki/Elliptic_curve_arithmetic
    I can't even compile it under MorphOS and on Linux all but the fixed co-ordinates are Not-A-Numbers.
  • »26.05.15 - 09:07
    igracki
    Posts: 469 from 2003/2/24
    The python version works here!
    0:00.60 [ 1] MOSBOOT:> c:python3 rosetta.py
    a = (-1.817, 1.000)
    b = (-1.442, 2.000)
    c = a + b = (10.375, -33.525)
    d = -c = (10.375, 33.525)
    c + d = Zero
    a + b + d = Zero
    a * 12345 = (10.759, 35.387)
  • »26.05.15 - 09:40
    bigfoot
    Posts: 510 from 2003/4/11
    There's a bug in the C code, or at least a difference from how the Python version works.
    In the from_y() function, replace
    r.x = pow(y * y - C, 1.0/3);
    with
    double tmp;
    tmp = y * y - C;
    if (tmp >= 0)
    r.x = pow(tmp, 1.0/3);
    else
    r.x = -pow(-tmp, 1.0/3);
    That'll make it behave identically to the Python version, and also give an identical result.
    The code as it is compiles fine for MorphOS, at least if you use GCC 4.
  • »26.05.15 - 16:44
    ausPPC
    Thank you. Now I get the expected output when compiled on Linux (gcc 4.8.2) but I might be experiencing a corrupted SDK. I'm downloading the sdk again and will do a checksum against the file I installed from...
  • »26.05.15 - 23:00
    ausPPC
    The sdk archive I installed from seems to be the same as the newly downloaded one but gccselect isn't behaving as expected. I only managed to compile the fixed source code by entering ppc-morphos-gcc-4
    Are gccselect and gccselect4 supposed to require a full path to work? After trying:
    > sdk:gccselect4 4.4.5
    and:
    > gcc --version
    it still reported 2.95.3
  • »26.05.15 - 23:59
    Posts: 3332 from 2003/3/5
    gccselect4 selects the version to use when invoking ppc-morphos-gcc-4. To change the default gcc link, use gccselect.
  • »27.05.15 - 04:13
