Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
Developer Forums
Development
So C or C++ for MorphOS development?
TheMagicM
# 1
Posts: 1220 from 2003/6/17
which is the way to go?
21.05.15
03:27
Daytona675x
# 2
Posts: 109 from 2013/12/5
Select the one you like most.
21.05.15
05:03
Posts: 632 from 2004/4/15
The System Api is C.
You can use Cpp, but if you want to use Mui you better choose C.
Or you mix it.
05:56
