How i can get id3tags from mp3 with reggae?
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    I know how i can play sound with reggae.
    But i don't know how i can get the id3tags from mp3.
    Can anybody help me.
  • »21.10.14 - 11:34
    Posts: 1076 from 2004/9/23
    mti = (struct MetaItem*) MediaGetPort( mediaobject, 0, MMA_MetaData );
    Then you can access the mti structure and obtain the information you need.
    struct MetaItem *mti is an array of meta stuff just like it is done for tooltypes and valid
    until mi_Id is MMETA_BAD_ID, which is the last item in chain.
    Geit
  • »21.10.14 - 14:18
    Krashan
    Posts: 1107 from 2003/6/11
    Some additional information:
    1. MetaItem is defined in <classes/multimedia/metadata.h>.
    2. If MetaItem contains textual information, the text is encoded in UTF-32. It can be converted to the system charset with charsets.library.
    3. While id3tag.demuxer has a complete ID3v2 (2.2, 2.3, 2.4) and ID3v1 tag parser, only basic ID3v2 tags are supported.
    [ Edited by Krashan 21.10.2014 - 17:46 ]
  • »21.10.14 - 14:43
    zukow
    Posts: 650 from 2005/2/9
    parsing metadata is an old api, please use MMM_GetMetaItem for getting metadata, for example:
    DoMethod(filter, MMM_GetMetaItem, MMETA_Title, &importance, &data->title, MIBENUM_SYSTEM, 0);
  • »22.10.14 - 00:07
    Krashan
    True, looping over MetaItem table should be used only if one is interested in getting all available metadata. Programs reading only some predefined set, should use MMM_GetMetaItem(). For text data it takes care of charset conversion, as in rzookol's example. On the other hand, Geit's method is neither "hackish" nor obsolete, just less comfortable.
  • »22.10.14 - 03:41
