VoxelNoid issues on some systems
    Daytona675x
    Posts: 109 from 2013/12/5
    some people have reported the game to freeze their system, sometimes on startup, sometimes in between.
    So far no user was able to get any more information, like a crash-log or whatever. And I really checked the (system-independant) game code in depth, without finding anything problematic at all. On all other OSes it runs without problems so far.
    Anyway, one user just sent me this:
    After startup:
    Radeon: CCE_MMIO_WaitForIdle: Timeout while waiting for the CSQ queue to idle (available: 764, max: 768, rptr: 160, hwwptr: 163 swwptr: 164)
    WaitForIdle timeout!!! Access type: 00000002 RPTR 0x0 WPTR 0x0 RBBM_STATUS 0x80010140, CP_STAT c0002004
    WaitForIdle skipped due to Radeon hang
    WaitForIdle timeout!!! Access type: 00000001 RPTR 0x1 WPTR 0x0 RBBM_STATUS 0x80010140, CP_STAT c0002004
    After exit game i see 3 lines more like that:
    unsupported 4BPP CPU solid fill BltPattern()
    ...and the Morphos response dramatically slow down!
    I have PM G5, Radeon 9800 pro, Morphos 3.7
    I have to admit:
    I have zero idea what it means exactly (only that it's Radeon-driver-related :) ), but maybe somebody else does?
    And what may cause it? And / or how to work-around it?
    Thanks,
    Daniel
    [ Editiert durch Daytona675x 10.10.2014 - 07:56 ]
  • »10.10.14 - 09:46
    bigfoot
    Posts: 510 from 2003/4/11
    Short version: It means that the Radeon crashed.
    Can you please ask the user to use the MorphOS bug report tool to report the issue and then I will have a look as soon as I have time.
  • »10.10.14 - 09:55
    Daytona675x
    @bigfoot
    Thanks for reacting that fast! I just asked the user to do what you said.
  • »10.10.14 - 10:03
