Programming
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    Hi
    Are there any good starter guides or tutorials on programming in MorphOS. I am an okish java developer but do not have any c or C++ experience. I have downloaded the SDK but not any easy help there.
    Any help thanks
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »10.09.14 - 17:00
  • JJ
    JJ
    Thanks for the site link. Any recommendations on a c(++) book. ?
  • »12.09.14 - 19:27
    Posts: 2570 from 2003/2/24
    If you really just need a reference/introduction to the languages and allready know how to code, you should just start with the obvious Kernighan/Ritchie (C) or Stroustrup (C++).
    If you also need some coding lessons you have a wide choice from "..... for Dummies" to books discussing special purpose algorithms.
  • »13.09.14 - 06:19
    Tcheko
    Posts: 544 from 2003/2/25
    There is numerous free PDF for learning C programming. For example : http://c.learncodethehardway.org/book/
    Happy reading.
  • »13.09.14 - 07:35
    rebraist
    Posts: 96 from 2011/4/6
    Stay away from academic stuff like stroustrup, schildt and kernighan Ritchie. If you want to learn C/C++ without wasting time buy the books by deitel & deitel: if you already have a little experience in coding you'll learn c in a very short time.D&D books are practical with good advise on software engineering too.
    Sam440 Os4.1.6
    Aros-Aros-Aros.
  • »13.09.14 - 12:35
    ausPPC
    Posts: 543 from 2007/8/6
    This is a fairly large collection of C tutorial material aimed at HaikuOS but possibly still of interest here - http://darkwyrm-haiku.blogspot.com/
  • »13.09.14 - 19:15
  • JJ
    JJ
    Thanks for all advice. I can code okiish. I'm oracle certified :).
    So I take it I can use c or c++,to compile for morphos. So guessing I would be better off learning c++ ?
  • »14.09.14 - 05:13
    C and C++ use the same syntax, C++ only adds functionality for object oriented programming ontop of C, so you can't really learn C++ without leraning C.
    Wether to use C or C++ can be the start of some rather heated arguments so better just choose based on your prefered programming paradigm.
    Personally I really like to have all those classes of the STL at hand and so pretty much do all thinks in C++ even if my part of the code ist just plain C.
  • »14.09.14 - 05:52
  • JJ
    JJ
    We'll given my java experience probably best to go with c++ by the sounds of it. Thanks
  • »14.09.14 - 11:48
