Memory leaks with ASL Library
    BalrogSoft
    Posts: 171 from 2006/10/6
    Hi.
    I found that any example of ASL library produces memory leaks when AslRequest() is called, maybe is my fault, but I have tried different examples, and all have the same problem, using MUI asl functions produces the same behaviour.
    This is one example found on the web:
    ;/* filereq.c - Execute me to compile me with SASC 5.10
    LC -b1 -cfistq -v -y -j73 filereq.c
    Blink FROM LIB:c.o,filereq.o TO filereq LIBRARY LIB:LC.lib,LIB:Amiga.lib
    quit
    #include <exec/types.h>
    #include <exec/libraries.h>
    #include <libraries/asl.h>
    #include <clib/exec_protos.h>
    #include <clib/asl_protos.h>
    #include <stdio.h>
    #ifdef LATTICE
    int CXBRK(void) { return(0); } /* Disable Lattice CTRL/C handling */
    void chkabort(void) { return; } /* really */
    #endif
    UBYTE *vers = "$VER: filereq 37.0";
    #define MYLEFTEDGE 0
    #define MYTOPEDGE 0
    #define MYWIDTH 320
    #define MYHEIGHT 400
    struct Library *AslBase = NULL;
    struct TagItem frtags[] =
    ASL_Hail, (ULONG)"The Amiga file requester",
    ASL_Height, MYHEIGHT,
    ASL_Width, MYWIDTH,
    ASL_LeftEdge, MYLEFTEDGE,
    ASL_TopEdge, MYTOPEDGE,
    ASL_OKText, (ULONG)"O KAY",
    ASL_CancelText, (ULONG)"not OK",
    ASL_File, (ULONG)"asl.library",
    ASL_Dir, (ULONG)"libs:",
    TAG_DONE
    void main(int argc, char **argv)
    struct FileRequester *fr;
    if (AslBase = OpenLibrary("asl.library", 37L))
    if (fr = (struct FileRequester *)
    AllocAslRequest(ASL_FileRequest, frtags))
    if (AslRequest(fr, NULL))
    printf("PATH=%s FILE=%sn", fr->rf_Dir, fr->rf_File);
    printf("To combine the path and filename, copy the pathn");
    printf("to a buffer, add the filename with Dos AddPart().n");
    FreeAslRequest(fr);
    else printf("User Cancelledn");
    CloseLibrary(AslBase);
    Every time that this program is executed, the system memory doesn't recovers at all, every execution leaves less memory. Is this the normal behaviour?
    Here is the source and the executable file compiled with latest SDK and gcc 4.4.5.
    aslreq.lha
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »02.08.14 - 08:58
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    Try this source:
    int asl (char kopf[],BOOL save,STRPTR pattern,char dir_[150])
    unsigned char file[100] = "";
    unsigned char dir[100] = "";
    unsigned char path[100]= "";
    int filezahl = 0;
    AslBase = OpenLibrary("asl.library",40L);
    if (AslBase != NULL)
    if( (fr = AllocAslRequestTags( ASL_FileRequest,
    ASL_Hail, (ULONG) kopf,
    ASL_OKText, (ULONG) "OK",
    ASL_CancelText, (ULONG) "Cancel",
    ASL_File, (ULONG) "",
    ASL_Dir, (ULONG) dir_,
    ASLFR_DoSaveMode,save,
    ASLFR_DoPatterns,TRUE,
    ASLFR_InitialPattern,pattern,
    TAG_DONE ) ) )
    strcpy(file,fr->rf_File);
    strcpy(dir,fr->rf_Dir);
    strcat(path,dir);
    strcat(path,"/");
    strcat(path,file);
    strcpy(path2,path);
    if (strstr(path,":/") != 0)
    unsigned char path[100] = "";
    strcat(path,dir);
    strcat(path,file);
    strcpy(path2,path);
    else
    if (IoErr())
    /*Es wird 0 in path2 kopiert, wenn man den Close-Button oder "Cancel" betätigt.*/
    strcpy(path2,"0");
    return 0;
    else
    strcpy(path2,"0");
    return 0;
    FreeAslRequest(fr);
    else
    /* Es wird -1 in path2 kopiert, wenn man nicht die asl.library öffnen kann.*/
    strcpy(path2,"-1");
    return -1;
    return 1;
    The global variable path2 inhibit the selected path.
    BalrogSoft wrote:
    Hi.
    quit
    #include <stdio.h>
    #ifdef LATTICE
    #endif
    #define MYTOPEDGE 0
    #define MYWIDTH 320
    ASL_Width, MYWIDTH,
    TAG_DONE
    FreeAslRequest(fr);
    aslreq.lha
  • »02.08.14 - 09:20
    BalrogSoft
    I have the same problem with your code, the system loses 50 kb approximately each execution.
  • »02.08.14 - 09:55
    BalrogSoft
    The problem with ASL Library is not only with this code. Any application that uses ASL library have the same problem, each call to AslRequest generate a memory leak of 50kb approx. even if cancel button is pressed, any system tool using ASL lib like FileImageCtrl have the same issue, it seems that it's not my fault, but is this a normal behaviour?
    [ Edited by BalrogSoft 04.08.2014 - 09:46 ]
  • »04.08.14 - 08:40
    Posts: 3332 from 2003/3/5
    50kB sounds bad for sure. I will have a look at what might be going on there...
  • »04.08.14 - 09:34
    igracki
    Posts: 469 from 2003/2/24
    how do you measure the memory leak?
    [ Edited by igracki 04.08.2014 - 11:33 ]
  • »04.08.14 - 10:16
    igracki
    here it also leaks ~50kb!
    I used this script for measuring (with your example):
    avail fast > env:m1
    r:aslrequest
    avail fast > env:m2
    rx "say $m1-$m2"
  • »04.08.14 - 10:33
    Are you sure you don't have thumbnails in ASL enabled?
  • »04.08.14 - 12:53
    BalrogSoft
    Thumbnails weren't used on my testings, all ASLcalls to AslRequest for a file requester produces a memory leak, Ambient preferences, MorphOS tools, Scribble, just open a file requester and close it, the system will lose 50kb.
  • »04.08.14 - 16:01
    Identified and fixed for 3.8. Thanks for reporting!
  • »04.08.14 - 18:14
    BalrogSoft
    You're welcome, and thanks for your quick response, I can work with my code after know that it isn't the cause of this memory leak.
  • »05.08.14 - 21:46
