Posts: 109 from 2013/12/5
Henes schrieb:
So... different behaviour and bugs are to be expected.
Indeed...
Turns out that some socket code isn't working now, great.
Okay, since I have full control about how this program is used I will workaround the argv[0] issue by simply calling the program with another additional parameter, containing what argv[0] should be if things were sane, and use ixemul.
Easier to work around that issue than to start looking for that socket-problem -noixemul introduced.
Thanks anyway!
