GCCSelect doesn't change LD
    ChrisH
    Posts: 167 from 2009/11/26
    My up-coming new release of PortablE is much faster, but to make it run as fast as possible I need a newer version of GCC than the MorphOS SDK provides (AROS, OS4 & Windows don't have this problem). Someone kindly pointed-out the SDK:GCCSelect program, but this doesn't appear to change the version of LD (which is missing the new feature I need).
    Does anyone have any suggestions? It needs to be something simple enough that anyone could make the necessary changes to their SDK (or that I could possibly automate as part of the installer program).
  • »07.04.14 - 18:49
    Posts: 1521 from 2003/2/24
    Umh, you should not need different version of LD. What is the error message there? You could try linking just with gcc/g++, that is what I do no matter am I compiling with GCC 2 or GCC 4.
  • »07.04.14 - 19:35
    Posts: 3332 from 2003/3/5
    There is no need for you to force anyone to change the default compiler. You should use ppc-morphos-*-4 directly if you rely on GCC4 features.
  • »08.04.14 - 05:12
    ChrisH
    @itix
    I need the ability to supply command line parameters from a file (they can be too long for the command line) using @file. GCC v2 doesn't support this, but GCC v4 does support it... however with the MorphOS SDK the old v2.x LD command doesn't seem to like it (probably unsurprisingly).
    I can work-around the lack of this feature, but it introduces a speed hit.
    @jacadcaps
    Thanks for the suggestion. I'd noticed that option, but I was sure if doing it that way would work (since the other sym links point to the old v2 GCC).
  • »08.04.14 - 10:32
    By design, the default compiler is GCC 2.95.3. ppc-morphos-gcc-4 and family always point to the default gcc-4. Usually that will be the latest gcc4 available in the SDK, so that is what you want to use.
  • »08.04.14 - 12:01
    CISC
    Posts: 619 from 2005/8/27
    ChrisH wrote:
    @itix
    MorphOS doesn't have a command line length limitation.
    - CISC
  • »10.04.14 - 03:02
    ChrisH
    *Something* has a command line length limitation, even if it is GCC or LD itself.
  • »16.07.14 - 15:10
  • ede
    ede
    Posts: 35 from 2011/4/18
    Check the SDK 2.7 if you need GCC 2.95.3. I remeber that SDK 3.4 with GCC 2.95.3 was bad for me, especially in linking process.
    [ Edited by ede 24.07.2014 - 09:57 ]
  • »19.07.14 - 04:13
  • ede
    ede
    [ Edited by ede 19.07.2014 - 04:19 ]
  • »19.07.14 - 04:14
