libcurl as a .library?
    igracki
    Posts: 469 from 2003/2/24
    why is there no curl.library?
    I searched the whole net (almost;) but only found libcurl to link with C programs.
    I would like to use it from an E source, because my gTranslator.sbar doesn't work anymore because google redirects my urls to https, and reggae's http.stream seems to not support it;(
    And I found out that the command line tool curl is able to get the url.
  • »03.05.14 - 20:41
    Posts: 1521 from 2003/2/24
    It could be done but at least I dont have time for that until I have completed my another project.
  • »04.05.14 - 04:53
    Posts: 3332 from 2003/3/5
    I'd make more sense to add https support to Reggae...
  • »04.05.14 - 06:08
    igracki
    Thanks, itix!
    Yes, https support for http.stream would be better of course, but I think a curl.library could be build faster;)
  • »04.05.14 - 11:27
    zukow
    Posts: 658 from 2005/2/9
    weren't sputnik included curl.library?
  • »04.05.14 - 11:29
    igracki
    zukow, you're right! I found it in my old backups!
    Need to find some dev infos now...
  • »04.05.14 - 11:38
    asrael22
    Posts: 451 from 2014/6/11
    Hi.
    libcurl would be great.
    It would be a great addition to the system as a whole. I would assume quite a bit of application today have some kind of HTTP connectivity going on.
    Manfred
  • »15.06.14 - 13:22
