Missing atan2() function
    Minuous
    Posts: 163 from 2010/2/12
    I'm #including <math.h> but still getting this error message from GCC:
    undefined reference to `atan2'
    This code used to compile before I had to reformat and reinstall everything. :-( Am I missing some component?
    It compiles fine under OS3.9 (SAS/C) and Windows (Visual C), just not MOS.
    Isn't atan2() part of ANSI C (C89)?
  • »02.05.14 - 09:34
    BSzili
    Posts: 567 from 2012/6/8
    Are you linking against libm.a? (-lm)
  • »02.05.14 - 09:40
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    You must define your own function. Atan2 did't exists in ANSI C of MorphOS
  • »02.05.14 - 11:51
    bigfoot
    Posts: 510 from 2003/4/11
    Sorry, this is not true. MorphOS' libm does have the atan2() function. BSzili's answer is likely the correct one.
  • »02.05.14 - 15:11
    Minuous
    Yes, -lm fixes the issue. Many thanks to you all.
  • »02.05.14 - 22:16
