Locale/OpenCatalog()
    igracki
    Posts: 469 from 2003/2/24
    I tried to localize my yWeather sbar, but I encountered a problem, the catalog is only read if it is in PROGDIR:catalogs/, but it should try to load from LOCALE:catalogs/ if there is no PROGDIR:catalogs/, right?
    That what old locale autodocs says.
    Is it a bug or am I doing something wrong?
  • »03.03.14 - 18:21
    Tcheko
    Posts: 544 from 2003/2/25
    What's your OpenCatalog argument ?
    Does Snoopium says something ?
  • »03.03.14 - 18:32
    igracki
       cat_yWeather:=OpenCatalogA(loc,'yWeather.catalog',
    [OC_BUILTINLANGUAGE, 'english',
    tag, tagarg,
    OC_VERSION, 0,
    TAG_DONE,0])
    I used current flexcat v2.13 with E32e.sd file.
    Snoopium does 3 times this:
    loctest Open PROGDIR:Catalogs/deutsch/yWeather.catalog Read Fail
  • »03.03.14 - 18:56
    Posts: 1521 from 2003/2/24
    igracki wrote:
    It should. Maybe you are using wrong version number? Version number must be an exact match unless versio 0 is requested.
    Locale.library is trying to find catalog in following order:
    1) PROGDIR:Catalogs
    2) MOSSYS:Locale/Catalogs
    3) LOCALE:Catalogs
  • »03.03.14 - 18:57
    Oh... What locale.library version are you using?
  • »03.03.14 - 19:04
    igracki
    v51.29
  • »03.03.14 - 19:07
    igracki wrote:
    v51.29
    It is buggy :) get one from 3.5 ISO or wait for next nightly :)
  • »03.03.14 - 19:09
    igracki
    ok, thanks!
  • »03.03.14 - 19:11
