searching for a XML editor
    serge
    Posts: 725 from 2003/2/20
    Hi guys,
    I'm searching for a XML editor.
    Unfortunatly Scribble dont recognize xml.
    thanks for advance
    Serge
  • »18.02.14 - 19:22
    Develin
    Posts: 100 from 2003/4/19
    @serge
    You could probably use Annotate for xml syntax colouring.
  • »19.02.14 - 09:55
    zukow
    Posts: 649 from 2005/2/9
    @serge
    I released
    http://aminet.net/text/show/xmlviewer.lha
    some years ago.
    but it only supports viewing/removing/pasting subtrees. I may add some utf8 fixes but don't have time now for adding full edit mode.
  • »19.02.14 - 20:53
    GMKai
    Posts: 257 from 2003/4/7
    serge wrote:
    Hi guys,
    thanks for advance
    Serge
    try an online one:
    XMLGrid
  • »20.02.14 - 08:07
    Nadir
    Posts: 175 from 2003/3/17
    serge wrote:
    Hi guys,
    thanks for advance
    Serge
    Scrible does in fact have xml support through the html lexer. Both syntax highlighting and folding works fine.
    You might need to add xml filename extension in the settings as this is not default in the current version.
    Also, I noticed that there is some kind of bug with folding when manually switching the language through the menus and I will fix it for the next release.
    Best,
    Nicholai
  • »23.02.14 - 10:41
