Bug in MUI Floattext?
    ciVic
    Posts: 45 from 2013/6/2
    Hi all,
    I want to create multiple floattexts during runtime on a Scrollgroup/VGroupV, so some of them are not visible. The floattexts that are initially visible are rendered correctly but when I scroll down to the other floattexts the text is not displayed, they are empty. I have to resize the window before the text is rendered.
  • »18.02.14 - 07:07
    Posts: 3336 from 2003/3/5
    Got some example source?
  • »18.02.14 - 08:39
    ciVic
    I create the Scrollgroup with
    Child, ScrollgroupObject,
    MUIA_Scrollgroup_Contents, content = VGroupV, VirtualFrame,
    End,
    End,
    and add in a loop this
    Object *v = (Object*)HGroup,
    GroupFrameT(date),
    Child, FloattextObject,
    MUIA_Floattext_Text, text,
    End,
    End;
    with this command
    DoMethod(content,OM_ADDMEMBER, v);
    This way I add 10 - 20 of (different) v.
  • »18.02.14 - 17:36
    Krashan
    Posts: 1107 from 2003/6/11
    You should call MUIM_Group_InitChange method on a group before adding objects to it dynamically, then MUIM_Group_ExitChange after they are added.
  • »19.02.14 - 03:19
    ciVic
    I'm sorry, fogot to mention that I call that before the loop starts and after it ends.
  • »19.02.14 - 04:11
    Posts: 2575 from 2003/2/24
    Kinda remember having a similar problem with poppen or coloradjust where a setattrs on hidden wouldnt update the gfx.
    AFAIR there were 2 options either set those attributes at object creation or force a redraw directly after setattrs.
  • »19.02.14 - 09:50
    ciVic
    I tried that redraw but I assume I did it not correctly. How should I do that? Btw. NFloattext works.
  • »19.02.14 - 09:53
    ciVic wrote:
    I create the Scrollgroup with ...
    OK. I will try to have a look soon.
  • »19.02.14 - 11:09
