Posts: 874 from 2007/4/9
Quote:Leif wrote:
boot_wb wrote:
Filesysbox was released under APL in 2011, and since 3.0 (2012) it has been part of MorphOS.
I can't find any link for the updated filesysbox sources, so was the MorphOS version in some way branched prior to filesysbox's APL release?
I changed the license for the MorphOS version.
I don't even have to ask anyones permission for that as
I am the sole copyright holder of the sources.
So: The MorphOS version is simply not covered by APL.
Only the 0.730 version was.
@Leif
Thanks for the clarifying. A little sad that development/bugfixes won't automatically be shared between systems (any AmigaOS bugfixes/updates will be covered by APL), but such is life I suppose, and it's good of you to open your sources for others at all.
Many thanks for filesysbox & ntfs3g, it's been in daily use here since I can't even remember how long.
www.hullchimneyservices.co.uk
Windows free since 2011!
