Developing for Morphos : questions
    kamelito
    Posts: 103 from 2011/9/21
    Hi
    Is the development documentation which was present at mdc site present in the wiki and/or SDK?
    Is the available doc in the wiki can be considered complete? If not is the wiki enough to find it's way through the SDK?
    What parts of the RKRM are obsolete if any to program for Morphos?
    Is the knowledge learned to program Morphos today will be still valid to program Morphos natively when the architecture switch will happen? (even if it's not for tomorrow)
    Thanks
    Kamwlito
    [ Edité par kamelito 13.01.2014 - 20:22 ]
  • »12.01.14 - 14:45
    Posts: 3327 from 2003/3/5
    Likely not all of it. The recent SDK was built from scratch from the materials that we have in the MorphOS source tree so there are likely things missing from it that were available in the past.
    Sadly, they are not complete. We do not have the resources to write proper docs for all the components inherited from AOS, so supplementing the SDK docs/guides with a AOS 3.x SDK is probably a good idea. Most of the new/changed functions are documented though.
    All the hardware related parts and many older techniques are obsolete. CBM used to document a lot of internal structures and so people were used to peeking and poking into these. We have instead decided to create special functions to read/modify those fields (see all the new exec.library functions for example). Another thing is the GUI parts - the MorphOS GUI apps shall always use MUI for which we provide pretty good documentation and examples.
    That's a bit hard to say at this stage.
    [ Edited by jacadcaps 14.01.2014 - 10:13 ]
  • »14.01.14 - 07:50
    Intuition
    Posts: 1116 from 2013/5/24
    @Kamelito
    This is a useful online reference for the stuff inherited from AOS.
    http://amigadev.elowar.com
  • »14.01.14 - 08:37
    kamelito
    @jacadcaps
    Thanks for answering my questions, it's much appreciated.
    @Intuition, thanks for the link even though I own the real materials.
    Regards
    Kamelito
  • »14.01.14 - 10:38
    kamelito
    @jacadcaps
    Can't edit my reply :(
    Just one more thing is the MDC material not present still relevant or important to Morphos programming?
    Does someone still have what was there? (MDC site)
    Kamelito
  • »14.01.14 - 10:41
    Intuition
    kamelito wrote:
    @jacadcaps
    Regards
    Kamelito
    No worries. Sometimes it's easier to do a quick search than get the RKRM's down from the shelf. :)
  • »14.01.14 - 10:42
