PowerSDL and noixemul
    Intuition
    Posts: 1113 from 2013/5/24
    Either i'm an idiot (Highly likely) or I missed it in the docs somewhere that when writing code that uses the SDL framework one must pass the -noixemul flag to gcc otherwise running the compiled binary locks up MorphOS completely.
    Justy thought I'd mention it here to save anyone else a similar headache.
  • »05.01.14 - 14:31
    Henes
    Posts: 507 from 2003/6/14
    Two more points:
    1. to compile a SDL source, the usage it to put `sdl-config --cflags` on the gcc commande line. This will add the -noixemul switch and the right include path. And use `sdl-config --libs` to link.
    2. -noixemul should pretty much be used for... everything. As soon as you make something doing any non-ixemul library call, use -noixemul. Always. An OpenGL call? An exec.library call? A z.library call? Anything not being part of ixemul's libc API? Use -noixemul.
  • »05.01.14 - 15:55
    Intuition
    Henes wrote:
    Two more points:
    Thanks for the tips Henes.
    I generally use -noixemul but I left it off the command line by accident and spent the next half an hour convinced I was going mad. :)
    Will make sure to use sdl-config in future.
  • »05.01.14 - 16:20
    tolkien
    Posts: 550 from 2013/5/29
    A noob question. How do I include the SDLconfig file in the command line to compile properly?
    [ Edited by tolkien 05.01.2014 - 18:28 ]
  • »05.01.14 - 16:27
    Henes
    The same way as on other systems:
    gcc -O3 `sdl-config --cflags` -c foo.c -o foo.o
    gcc `sdl-config --libs` foo.o -o foo
    Please notice the backtick usage.
  • »05.01.14 - 17:00
    tolkien
    Thanks Henes. I've never used the config file. Time to do thing right. ;)
  • »05.01.14 - 17:25
    Intuition
    I can give you a makefile i knocked up if you want?
  • »05.01.14 - 20:58
    tolkien
    Thanks Intuition! It will be useful when I repair my two macs.
    I was doing some SDL stuff.
  • »05.01.14 - 22:00
    Intuition
    CXX = ppc-morphos-g++
    STRIP = ppc-morphos-strip
    CFLAGS = -O3 -Wall `sdl-config --cflags`
    LDFLAGS = `sdl-config --libs`
    SOURCES = image.cpp
    OBJECTS = $(SOURCES:.cpp=.o)
    EXECUTABLE = image
    all: $(SOURCES) $(EXECUTABLE)
    $(EXECUTABLE): $(OBJECTS)
    @echo "Linking object code and creating executable...."
    @$(CXX) $(CFLAGS) $(OBJECTS) -o $@ $(LDFLAGS)
    @echo "Stripping extraneous data from executable...."
    @$(STRIP) --strip-all $(EXECUTABLE)
    @echo LZMA-packing executable....
    @copy C:lzmaLoader $(EXECUTABLE).packed
    @lzma e $(EXECUTABLE) -so >>$(EXECUTABLE).packed
    @echo
    @echo "All done!"
    @echo
    @echo "Executable filename is: '$(EXECUTABLE)'"
    @echo "Packed executable filename is: '$(EXECUTABLE).packed'"
    @echo
    .cpp.o:
    @echo "Compiling object code...."
    @$(CXX) $(CFLAGS) -c $< -o $@
    clean:
    @rm -f $(OBJECTS) $(EXECUTABLE) $(EXECUTABLE).packed
    @echo "All objects and executables have been cleaned."
    @echo
    You can delete the LZMA-loader lines if you want, or just copy lzma, lzmaLoader and lzmaLoader_shared to C:
    http://morphos-files.net/remote/LZMALoader
  • »05.01.14 - 22:09
    tolkien
    Great Intuition! Thanks so much. Ill change It as I need It.
  • »06.01.14 - 01:07
    Intuition
    tolkien wrote:
    Great Intuition! Thanks so much. Ill change It as I neeIt.d
    You're welcome. :)
  • »06.01.14 - 01:45
