MUI-String edithook
    Posts: 2570 from 2003/2/24
    Hi guys, trying to create a string gadget where th 1st n characters are read only.
    First try was with MUIA_String_Bufferpos, but that doesnt seen to trigger a notify.
    Now looking into supplying my own edithook but cant find much of docu..
    So how do I check wether user moved cursor to far right and than eat that event ?
  • »14.10.13 - 17:01
    Posts: 3332 from 2003/3/5
    Edithooks are unsupported.
  • »14.10.13 - 18:54
    Tcheko
    Posts: 544 from 2003/2/25
    Subclassing string object might help with your requirement.
    search for MUI_EventHandlerRC_Eat for example.
    [ Edited by Tcheko 14.10.2013 - 23:02 ]
  • »14.10.13 - 19:00
    igracki
    Posts: 469 from 2003/2/24
    you could use two string gadgets, first readonly, second editable.
    Use no space between them and put a string-frame around both string-gads.
  • »16.10.13 - 15:43
