printf output and SDL
    tolkien
    Posts: 578 from 2013/5/29
    Hi friends.
    Im doing some stuff with SDL and know that printf() is "disabled" under SDL. Well, normally Its redirected to some files.
    If I write freopen("con:", "w", stdout); after SDL_Init() I can see a shell window opening and close quickly. I guess all printf() stuff is there but I cant see it.
    My question is how can I see the result or stay the con: open?
  • »14.10.13 - 14:24
    Intuition
    Posts: 1116 from 2013/5/24
    I have no experience with SDL but can you not use Printf() from dos.library?
  • »14.10.13 - 15:03
    tolkien
    mmmmm...good question!!! hehehehe Im under a PC now but will try in a few minutes!
    Thanks for the tip Intuition!!
  • »14.10.13 - 15:12
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    It strange. I am using SDL to creating my multiplatform crappy applications. Result of printf() function is visible on CLI which is opened when I run the application.
  • »14.10.13 - 16:04
    Intuition
    You're welcome. Hope it works. :)
  • »14.10.13 - 16:24
    Posts: 1521 from 2003/2/24
    SDL libraries dont prevent using printf(). There are restrictions in the library code itself but you can continue using standard c library stuff.
  • »14.10.13 - 16:37
    tolkien
    But i have a fresh install and Im unable to see any result using printf(). Perhaps Im doing something wrong. Ill try later but thanks for answer!
  • »14.10.13 - 16:59
