Xad pratical usage
    Posts: 186 from 2003/10/23
    i need some basic info on xad usage to decrunch some file
    i've downloaded the sourceforge archive, but the examples won't compile
    there is some code available to watch?
    I'm nerdy in the extreme
    And whiter than sour cream
    White&Nerdy 2006 Al Yankovic
  • »17.09.13 - 07:00
    connor
    Posts: 650 from 2007/7/29
    What do you need help for? Ambient supports some archive types to decrunch. You can unpack them from context menu or enter them from doublecliking. Just some filetypes do not list a content.
  • »17.09.13 - 09:06
    Posts: 1092 from 2004/9/23
    Xad is part of MorphOS it is used in various places.
    XAD2LhA 12637 ----rwed 07-Sep-13 10:39:06
    XADLibInfo 3067 ----rwed 07-Sep-13 10:39:06
    XADList 7039 ----rwed 07-Sep-13 10:39:06
    XADUnDisk 13044 ----rwed 07-Sep-13 10:39:06
    XADUnFile 9682 ----rwed 07-Sep-13 10:39:06
    XADUnTar 10056 ----rwed 07-Sep-13 10:39:06
    There is no need to install anything.
    Geit
  • »17.09.13 - 09:21
    Geit
    yes, i know, i know :)
    maybe i expressed myself badly, i need some info on how to use xad.lib in a program :D
    (we are in the developement forum after all ;) )
    specifically i need zip and rar support (maybe xad is a no go and i need to link other library to decompress them)
  • »17.09.13 - 10:32
    Mazze
    Posts: 20 from 2010/11/6
    raistlin77it schrieb:
    Geit
    Somewhere in the archive is documentation.
    http://libxad.cvs.sourceforge.net/viewvc/libxad/
    I had written an Unarc clone for AROS. I can send you the source if you need it.
  • »18.09.13 - 14:44
    yes please, the more sources i look the more i understand :D
    edit... i've found it in the aros contrib sources :)
    [ Edited by raistlin77it 19.09.2013 - 17:07 ]
  • »19.09.13 - 06:50
    Mazze
    Good find :-)
  • »19.09.13 - 16:11
